November 22, 2022, 03:33 |
Foam Fatal error
harshavardhan
Rep Power: 8 |
I am running a DPM simulation, where I am injecting spray using hollow cone method. The simulation is performed for 12sec. I could see that the simulation has completed 12sec time period, but throwing an error file as shown below. I would like to understand if there is an error in the simulation.
Loading OpenFOAM/2112 Loading requirement: openmpi/4.1.2 [gadi-cpu-clx-2477:434319] *** An error occurred in MPI_Recv [gadi-cpu-clx-2477:434319] *** reported by process [2433810433,4] [gadi-cpu-clx-2477:434319] *** on communicator MPI_COMM_WORLD [gadi-cpu-clx-2477:434319] *** MPI_ERR_TRUNCATE: message truncated [gadi-cpu-clx-2477:434319] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, [gadi-cpu-clx-2477:434319] *** and potentially your MPI job) [gadi-cpu-clx-2477.gadi.nci.org.au:434305] PMIX ERROR: UNREACHABLE in file /jobfs/35197837.gadi-pbs/0/openmpi/4.1.2/source/openmpi-4.1.2/opal/mca/pmix/pmix3x/pmix/src/server/pmix_server.c at line 2198 -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [gadi-cpu-clx-2477.gadi.nci.org.au:434305] PMIX ERROR: UNREACHABLE in file /jobfs/35197837.gadi-pbs/0/openmpi/4.1.2/source/openmpi-4.1.2/opal/mca/pmix/pmix3x/pmix/src/server/pmix_server.c at line 2198 [0] [0] [0] --> FOAM FATAL IO ERROR: (openfoam-2112) [0] Bad token - could not get fileName [0] [0] file: stream at line 0. [0] [0] From Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::fileName&) [0] in file primitives/strings/fileName/fileNameIO.C at line 69. [0] FOAM parallel run exiting [0] [gadi-cpu-clx-2477.gadi.nci.org.au:434305] 6 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal [gadi-cpu-clx-2477.gadi.nci.org.au:434305] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
cfd air pollutants, foam fatal io error, openfoam |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
