Help - absorption for solid in chtMultiRegion and non-participate gas in fvDOM |
December 14, 2022, 05:38 |
Rep Power: 3 |
I want to run a derived case from the hotRadiationRoomFvDOM in the tutorial of openFoam v2206, in which the heater is modelled with a solid. I want to let the gas is non-participate about radiation, i.e. the solid heater transfer heat with the wall by radiation while the gas transfer heat with the solid heater and the wall by convection. In addition, I set the T of the wall to 1000 K, i.e. higher than the solid heater. As hotRadiationRoomFvDOM, I use chtMultiRegionSimpleFoam + radiation. The radiation model is FvDOM for gas. I have two questions: 1. In order to let the gas non-participate about radiation, I want to set absorption and emissivity of gas to a very low value. I can run the case successfully with absorption = emissivity = 0.1 for gas. But with absorption = emissivity = 0.05 or 0.01 for gas openFOAM fails to run after 3 time steps and said Negative Initial Temperature for the gas. 2. I want to change the absorption of the solid, but with absorption = 1 or = 0 in constant/SOLID/radiationProperties, I got the same results. solidAbsorption has been set for wallAbsorptionEmissionModel in constant/FLUID/boundaryRadiationProperties. Could anyone give light on my questions? I use openFOAM v2206. Thank you in advance! |
