November 24, 2019, 17:46 |
createPatch command
mekim
Rep Power: 6 |
Hi, i run with createPatch command and i checked polyMesh boundary file and 0 file. i cannot see any problem.
Could anyoone guide me how to do ? Thanks everyone who will answer --> FOAM Warning : From function const Foam::HashTable<Foam::List<int>, Foam::word>& Foam:olyBoundaryMesh::groupPatchIDs() const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 473 Removing patchGroup 'wall' which clashes with patch 6 of the same name. --> FOAM Warning : From function Foam::labelHashSet Foam:olyBoundaryMesh:atchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching cyclic1 --> FOAM Warning : From function Foam::labelHashSet Foam:olyBoundaryMesh:atchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching cyclic2 --> FOAM Warning : From function Foam::labelHashSet Foam:olyBoundaryMesh:atchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching cyclic1 --> FOAM Warning : From function Foam::labelHashSet Foam:olyBoundaryMesh:atchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching cyclic2 |
November 25, 2019, 06:54 |
Ingo Riess
Rep Power: 6 |
From the warning messages, I guess, you've got the syntax of createPatchDict wrong. Apparently, you tried to use the patch name 'wall' twice. Maybe there is already a patch 'wall' in your model. And possibly, you tried to use faceSet names that aren't defined (e.g. in topoSetDict). If you post the file createPatchDict, maybe we'll know more.
November 25, 2019, 13:31 |
mekim
Rep Power: 6 |
thank u for answering.
My createPatch file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Patches to create. patches ( { //- Master side patch name periodic1; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch periodic2; // transform noOrdering; transform translational; separationVector (0 -0.032841912 0); } constructFrom patches; patches (cyclic1); } { //- Slave side patch name periodic2; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch periodic1; // transform noOrdering; transform translational; separationVector (0 0.032841912 0); } constructFrom patches; patches (cyclic2); } { //- Master side patch name frontcyc; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch backcyc; // transform noOrdering; transform translational; separationVector (0 0 -0.0005); } constructFrom patches; patches (cyclic1); } { //- Slave side patch name backcyc; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch frontcyc; // transform noOrdering; transform translational; separationVector (0 0 0.0005); } constructFrom patches; patches (cyclic2); } /* { name inlet; patchInfo { type patch; } constructFrom set; set inletFaces; } { name outlet; patchInfo { type patch; } constructFrom set; set outletFaces; }*/ ); // ************************************************************************* // |
November 26, 2019, 03:31 |
Ingo Riess
Rep Power: 6 |
I don't understand the warning about patchGroup 'wall'. This name is not used in your createPatchDict. Maybe, you should also check the file /constant/polyMesh/boundary.
The other warnings are about patches to be created from the existing patches 'cyclic1' and 'cyclic2'. I expect, these patches must also be defined in /constant/polyMesh/boundary. If they are not there, createPatch cannot find them. |
November 26, 2019, 04:19 |
Kmeti Rao
Rep Power: 8 |
Hi Mekim, attaching your boundary mesh would help to find the error
November 26, 2019, 08:12 |
mekim
Rep Power: 6 |
thank u for your attention.
my boundary file: Code:
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } ( backcyc { type patch; nFaces 39606; startFace 78626; } periodic1 { type patch; nFaces 268; startFace 118232; } periodic2 { type patch; nFaces 268; startFace 118500; } frontcyc { type patch; nFaces 39606; startFace 118768; } inlet { type patch; nFaces 147; startFace 158374; } outlet { type patch; nFaces 119; startFace 158521; } wall { type wall; nFaces 370; startFace 158640; } ) |
November 28, 2019, 09:22 |
Ingo Riess
Rep Power: 6 |
So, this is your boundary file after running createPatch, is it? It seems fine. Maybe you tried to run createPatch twice?
November 28, 2019, 14:04 |
mekim
Rep Power: 6 |
I solved the problem. I edited the pacthes (..) part.
June 8, 2021, 20:19 |
'edited the patches (..) part' ??
#9 |
Alan w
Rep Power: 6 |
I am having the same problem, but I don't understand what you mean when you say you solved the problem. Can you give more detail about what you did with the 'patches (..)' part? |
January 15, 2022, 15:45 |
#10 |
Evren Yilmaz Yakin
Rep Power: 10 |
I am taking the same problem when I define wedges in my boundry and I can't solve the problem. Code:
--> FOAM Warning : Creating fvModels from "constant/fvOptions" Selecting finite volume model type radiation Name: radiation Selecting radiationModel P1 Selecting absorptionEmissionModel greyMeanCombustion Selecting scatterModel none Selecting soot model none --> FOAM Warning : From function const Foam::HashTable<Foam::List<int>, Foam::word>& Foam::polyBoundaryMesh::groupPatchIDs() const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 473 Removing patchGroup 'wall' which clashes with patch 5 of the same name. --> FOAM Warning : Creating fvConstraints from "constant/fvOptions" rather than system/fvConstraints No fvConstraints present
Best Regards, Evren |
January 18, 2023, 18:20 |
Rename group wall to walls.
#11 |
ms
Rep Power: 17 |
Allow me.
I had the same. My system/blockMesh showed, Code:
boundary ( wall { type wall; faces ( (0 1 2 3) (4 5 6 7) ); } ) Code:
boundary ( walls { type wall; faces ( (0 1 2 3) (4 5 6 7) ); } ) Apologies for the inline format. BR, Mark. |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
