Three phases (Air, water,particles) correct settings?
Old   February 13, 2023, 10:14
Default Three phases (Air, water,particles) correct settings?
ff
fxzf is on a distinguished road
Hello Foamers,
I need help from expert in multiphase flow.
I want simulate a three phases flow including Air, water and particles. As classic issue, I would like to use Eulerian method. Therefor, I would like to pick up multiphaseEulerFoam. However, because the particle is only existing in the water, I dont know what is corrected settings to avoid the mix between air and particles without water.
For example, in phaseProperties.
type basicMultiphaseSystem;
phases (particles air);
referencePhase air;
particles
type purePhaseModel;
diameterModel constant;
constantCoeffs
d 3e-4;
alphaMax 0.62;
residualAlpha 1e-6;
air
diameterModel none;
residualAlpha 0;
blending
default
type continuous;
phase air;
surfaceTension
interfaceCompression
drag
particles_dispersedIn_air
type GidaspowErgunWenYu;
residualRe 1e-3;
virtualMass
heatTransfer
type RanzMarshall;
residualAlpha 1e-4;
phaseTransfer
lift
wallLubrication
turbulentDispersion
Could anyone advise me how to setup this settings for three phases flow?
Thanks very much!
fxzf is offline   Reply With Quote
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Cylinder-piston ( Air compression ) sidhant FLUENT 0 November 28, 2015 10:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 08:57
SOS: the nonpositive k and epsion ,how to get the correct boundary settings abbott.hn OpenFOAM Running, Solving & CFD 5 March 12, 2012 22:49
