FOAM FATAL ERROR: Unknown Model type scalarSemiImplicitSource |
February 18, 2023, 23:53 |
Akash Adithyan
I am currently working on natural cooling of Li-Ph cell using chtMultiregionfoam solver , with a const semi implicit heat source. On solving its showing unknown model type ERROR.
When i run chtMultiRegionFoam , it's showing following error Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to pRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulenceFluid Selecting turbulence model type laminar Selecting laminar stress model Stokes Adding to thermophysicalTransport Selecting thermophysical transport type laminar Selecting default laminar thermophysical transport model Fourier Adding to reactionFluid Combustion model not active: combustionProperties not found Selecting combustion model none Adding to radiationFluid Radiation model not active: radiationProperties not found Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding to fieldsFluid Adding MRF No MRF models present Adding fvOptions Creating finite volume options from "system/fvOptions" Selecting finite volume options model type scalarSemiImplicitSource --> FOAM FATAL ERROR: Unknown Model type scalarSemiImplicitSource |
February 20, 2023, 03:48 |
Rep Power: 5 |
Hey
If you are using a multiregion sovler, the fvOptions file needs to go in system/region1 instead of constant. I guess this could be the reason why OpenFoam could not locate your file. It also means that the fvOptions file applies only to its region, and you should write one fvOptions per region if needed. |
March 1, 2023, 02:52 |
Igor
Faced the same problem. Did you find the cause of the error?
convergence problem of steady 2D film cooling calculation using chtMultiRegionFoam | ruanyg968tf | OpenFOAM Running, Solving & CFD | 1 | April 10, 2024 02:23 |
[blockMesh] Issue with mergePatchPairs | JohnnyMercu | OpenFOAM Meshing & Mesh Conversion | 1 | May 30, 2021 00:24 |
reactingMultiphaseEulerFoam | tonnykz | OpenFOAM Running, Solving & CFD | 2 | June 15, 2020 02:09 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
