Changing position using setFields
Old   March 4, 2023, 15:53
Post Changing position using setFields
SaltyEnforcer
SaltyEnforcer is on a distinguished road
https://ibb.co/6g54WYJI am simulating with two fluids. In the parallel channel, I want to change the position of the fluid till the vertical channel which is (0.0018 0.0006 0.0006) but even after setting this in setFieldsDict I am getting varied results, the initial image from paraview is attached.
How do I increase the thickness till the vertical column using setFields?
SaltyEnforcer is offline   Reply With Quote
Old   March 5, 2023, 01:23
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I don't know if you can "change" the position. At least is is not a good way.
I recommend starting with internalField uniform 0; in the alpha file and use setFields to do all the rest.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
channel flow, setfieldsdict
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
Force dependent on particle position jranita OpenFOAM Programming & Development 1 August 23, 2011 19:44
changing position of Water column in dam break vivek070176 OpenFOAM 2 June 29, 2011 06:55
how to read in a position file jiejie OpenFOAM 0 May 23, 2011 04:38
