March 22, 2023, 01:18 |
simpleFoam crashes without error messages
Giles Richardson
Rep Power: 13 |
simpleFoam crashes (during 1st iteration) without error messages. It just stops running after the 3 momentum equation lines, and before the pressure equation, without any indication what the problem is.
The case is an MRF case using 2 zones connected with cyclicAMI interface, although the crash is probably related to a mesh error. I will have to run checkMesh again and scrutinise the output for any problems. I had a similar issue a while back and it was related to cells not connected to the main mesh properly, or just connected by one node. I will add a reply when the problem is fixed. |
March 22, 2023, 02:31 |
Rep Power: 3 |
I encountered a similar issue (crash without error), when I had too large mesh and too little memory (RAM) to work with such mesh.
I don't know if this is the case with you, I just thought it might help someone. Regards! |
March 22, 2023, 06:29 |
Giles Richardson
Rep Power: 13 |
thanks - got it running eventually...
I think the problem was because I had the wrong zone name in the MRFProperties file (it was zone1 and should have been zone0). But at the same time I remeshed both zones after removing the linkage geometry between the blades and fuselage - giving a nice clean gap, so there is no geometry on the cyclic interface. So the problem could have been caused by either of those 2 things. I have attached some notes which is what I use to help set up an MRF case. ====================== MRF case setup for AMI ====================== requires: -2 mesh directories - topoSetDict (to create inner MRF and outer mesh zones) - createPatchDict (to create cyclicAMI boundaries) - MRFProperties (to specify the rotation) start with cylinder, fuselage and blades geometry - cylinder is cyclic interface generate 2 seperate case directories - 1 for inner mesh, and 1 for outer mesh using snappyHexMesh - move point location for inner mesh (inside cylinder) - move point location for outer mesh (outside cylinder and fuselage in freestream) (move both dir 2 to 0) NOTE: check both boundary files have cyl-inner and cyl-outer as surface names use topoSetDict to create "zone0" *** for inner mesh use topoSetDict to create "zone1" *** for outer mesh then go above both case directories and use mergeMeshes <dir1> <dir2> this creates a new "1" dir in the <dir1>, so then move this "1" to "0" can use paraview with "read zones" toggled ON, to check the inner zones. ==== use createPatch to make the cyclicAMI boundaries for cyl-inner and cyl-outer - check that it says cyclicAMI in the createPatchDict file - check that it has the right surface names too then check that you have c1 aand c2 defined as cyclicAMI in boundary file check that there are 2 cell zones in cellZones file update the boundary files p U k omega nut with cyclicAMI (for c1 and c2) create or modify the MRFProperties file in "constant" dir to set omega (speed) - check you have got the right zone names - and check right surfaces in the MRF file run in simpleFoam as normal (fingers crossed) |
March 22, 2023, 14:11 |
Giles Richardson
Rep Power: 13 |
PS. I also found some mesh errors that needs fixing...
There were non-manifold points, which can be found by using: foamToVTK -pointSet nonManifoldPoints and some problem with edgefaces, when using checkMesh -allTopology foamToVTK -faceSet edgeFaces also some nonOrthogonalFaces on the cyclicAMI inner boundary, foamToVTK -faceSet nonOrthoFaces !!! (cause immediate crash) Then you can load them into Paraview and see where they are. https://twitter.com/garcfd/status/16...345152/photo/1 (twitter image) Last edited by ufocfd; March 23, 2023 at 14:17. |
March 26, 2023, 14:36 |
Giles Richardson
Rep Power: 13 |
PS. I have since learnt that its much quicker and simpler to mesh the (both inner and outer parts) at the same time and then setup without any cyclic AMI, you just add couple of lines in the snappyHexMeshDict, and then the MRF is ready to go (you don't even need to merge 2 separate meshes). The only thing you need to do is put the cellZone name (below) into the MRF properties file.
cellZone cell-inner-volume; faceZone face-inner-volume; mode inside; |
crash, simplefoam |
simpleFoam crashes after a few iterations - mesh issue? | NiklasH108 | OpenFOAM | 11 | July 29, 2020 11:19 |
simpleFoam crashes | Sean95 | OpenFOAM Running, Solving & CFD | 11 | March 15, 2018 05:07 |
cyclicAMI + simpleFoam crashes in parallel | jmf | OpenFOAM Running, Solving & CFD | 6 | June 28, 2017 15:30 |
SimpleFoam crashes after restarting simulation | fedez91 | OpenFOAM Running, Solving & CFD | 18 | September 4, 2016 08:59 |
potentialFoam & simpleFoam crashes after snappyhexmesh [parallel execution] | pilot320 | OpenFOAM Running, Solving & CFD | 10 | November 12, 2015 16:56 |
