Unexpected property distributions in Hy2Foam with non-slip wall condition
Old   May 27, 2023, 05:42
Default Unexpected property distributions in Hy2Foam with non-slip wall condition
Forrest WU
S1mple is on a distinguished road
I am a graduate student currently working on a simulation using Hy2Foam. My simulation involves high-speed non-equilibrium flow over a sphere. I have set the wall boundary conditions to non-slip with isothermal non-catalytic.
However, I have observed an unexpected property distributions: the temperature gradient from the first grid layer to the wall is significantly larger than the gradient from the second grid layer to the first. This discrepancy is causing very large value of heat flux when manually calculating the heat flux. The problem is we cannot do the calculations with non-slip wall conditions properly, and the jump is not only in the temperature, but in the velocities too.
It's possible that due to my limited experience, I'm unable to diagnose the problem. I would greatly appreciate any insights or advice you might have.
Thank you for your time.
S1mple is offline   Reply With Quote
Old   April 3, 2024, 04:50
Dengke Li
Iniesta8 is on a distinguished road
Has this problem been solved? I met some similar problems in simulating inviscid non-equilibrium via hy2Foam, the distribution of Tv and Tt at the wall is very strange. If you have time, we could discuss in details.
Iniesta8 is offline   Reply With Quote
heatflux, hy2foam, openfoam 17.06(v2)
CFD Simulation - Stagnation Temperature CellZone Main CFD Forum 2 November 3, 2021 13:30
Ahmed body simulation gives unexpected results in su2 6.0 anas651 SU2 0 March 28, 2018 03:42
Set gradient of temperature from outside kaanm OpenFOAM Programming & Development 1 December 27, 2017 06:55
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 07:29
