Chaitanya
Rep Power: 0 ![]() |
Since ferrofluid is a non-Newtonian magnetic fluid, I was wondering if it was possible to do a Multiphysics simulation here in OpenFOAM of a ferrofluid interacting with water and solid. Due to the movements of the ferrofluid, there will be changing magnetic fields around it, which I want to capture using a coil. I am new to the software, so I wanted to know if such a simulation is possible with it.
Basically, it will be multiphase flow between Newtonian and non-Newtonian fluids (air-water, water-ferrofluid, maybe air-ferrofluid as well). Then a fluid-solid interaction needs to be coupled (the ferrofluid will be in a half-open solid structure, imagine a ). Finally, the Electromagnetic solver needs to be added for the coil. I know it is a lot, but can I achieve this using OpenFOAM? |
cfd - post, electrodynamics |
How much does the source code for this turbulent flow CFD code worth in US $? | Dr Youssef Hafez | Main CFD Forum | 43 | January 4, 2023 01:13 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Low-Re Modelling | doerschlott | OpenFOAM Running, Solving & CFD | 4 | June 23, 2022 06:53 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
Ferrofluid flow modelling in fluent | Souviktor | FLUENT | 1 | January 10, 2016 04:21 |
