AMI/MRF Domain Dimensions
Old   November 3, 2022, 08:07
Smile AMI/MRF Domain Dimensions
Anuar Giménez
anuargimenez is on a distinguished road
I've just started with AMI/MRF simulations and going through some papers I have some doubts.
In most simulations, the dimensions of the computational domain are usually much larger than those of the area under rotation. Here you can see an example:
(article: http://www.koreascience.or.kr/articl...4753343875.pdf)
I want to simulate an extrusion screw using MRF and AMI. The problem is that there is no space between the stator and rotor, leaving a small gap for the AMI interface. Because of the problem geometry, the distance between the inlet, outlet and the rotating zone is also minimal.
Here you can see an example of my geometry:
When i run the MRF simulation, the viscosity results are not real. While running the AMI simulation it crashes.
Could it be because of the small distance between rotating zone and stationary zone?
anuargimenez is offline   Reply With Quote
Old   June 25, 2023, 10:51
Manuel Fermin Fonseca
manuelffonseca is on a distinguished road
Could you show us a pict of the Ami volume used? Maybe try o use the SRF (single reference frame).
manuelffonseca is offline   Reply With Quote
ami, mrf
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 08:09
Dimensions of a CFD computational domain samiahmed Main CFD Forum 3 July 9, 2019 08:43
Domain size influence in unbounded domains model Reoyo Main CFD Forum 10 May 4, 2018 08:30
Periodic Pressure drop cfd_begin CFX 10 May 25, 2017 07:09
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
