simpleFoam works for laminar flow but not for turbulent flow |
July 9, 2023, 21:51 |
Farzad Faraji
Rep Power: 7 |
Hello everyone
I have two geometries where one of them is a simple shape and the other one is more complicated; 1- simple geometry: Laminar and Turbulent(komegaSST) flow both works with no problem. 2- complicated geometry: Laminar works, but Turbulent gives error. For the complicated geometry checkMesh shows no problem at all, so I am only doubtful about my initial condition for k and omega(I am using komegaSST). By looking at the attached figure you can see what is my problem. Once, I tired o use transient sovler(pimpleFoam) to see if it work, but it works only for laminar flow for the second geometry which you can see in below link. courant number increases to rather large values I will be thank full if anyone answer my question. |
checkmesh, laminar, simplefoam, turbulent |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
parallel simpleFoam requires 0/s ; serial solution works | sral | OpenFOAM Running, Solving & CFD | 5 | October 17, 2019 08:55 |
Proper BCs for 3D exterior plate flow with simpleFoam? | CoolHand | OpenFOAM Pre-Processing | 2 | August 13, 2014 21:10 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
