Attempt to cast type zeroGradient to type nutWallFunction
Like Tree2Likes
  • 1 Post By HPE
  • 1 Post By CfdUser5855
Old   December 17, 2020, 08:47
Default Attempt to cast type zeroGradient to type nutWallFunction
Anon
CfdUser5855 is on a distinguished road
Hi all,
I'm running a pimpleFoam case, and the error
'--> FOAM FATAL ERROR:
From function To& Foam::refCast(From&) [with To = const Foam::nutWallFunctionFvPatchScalarField; From = const Foam::fvPatchField<double>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/typeInfo.H at line 114'
appears after initially solving for ux, uy, and uz. I have tried a number of different types for the patch to see if it will run, but the error appears each time with the different type used substituted into it.
A search for this error provides a link to people saying they have this problem, but no solution is working for me
My nut case is shown below
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
#include "include/ABLConditions"
inlet
type zeroGradient;
//value uniform 0.0;
outlet
type zeroGradient;
//value uniform 0;
top
type zeroGradient;
//value uniform 0;
NiliDuneField
type nutkAtmRoughWallFunction;
z0 0.03;
value uniform 0;
If anyone is able to help with this, that would be greatly appreciated
CfdUser5855 is offline   Reply With Quote
Old   December 17, 2020, 10:50
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
The reason of that error is bad class hierarchy change. Spilled from OpenFOAM.org...
Please just use a nut wall function in 0/nut file.
For example, if you have `fixedValue` for a patch inside 0/nut, please change it to `nutLowReWallFunction`. Then it should run.
govind_IITD likes this.
HPE is offline   Reply With Quote
Old   December 17, 2020, 12:35
Anon
Thanks for the advice, however the error then throws up that the patch type for inlet must be wall, which isn't correct for this simulation
Do you know which nut type would resolve that issue, without changing the wall type?
Old   December 17, 2020, 12:36
HPE
HPE's Avatar
would you mind to share the boundary condition files as well as constant/polyMesh/boundar*, please?
Old   December 18, 2020, 11:47
Anon
Sorry for being late getting back to you. I tried remaking the case to see if it was a redundant line that was causing the issue but no joy
My constant/polymesh/boundary is as follows
4
outlet
type patch;
nFaces 33775;
startFace 29542772;
inlet
type patch;
nFaces 28497;
startFace 29576547;
top
type patch;
nFaces 450;
startFace 29605044;
DuneField
type wall;
inGroups List<word> 1(wall);
nFaces 459920;
startFace 29605494;
p is as follows:
#include "include/initialConditions"
dimensions [0 2 -2 0 0 0 0];
internalField uniform $pressure;
boundaryField
inlet
type zeroGradient;
outlet
type uniformFixedValue;
uniformValue constant $pressure;
top
type zeroGradient;
DuneField
type zeroGradient;
ground
type zeroGradient;
u is as follows
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type atmBoundaryLayerInletVelocity;
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
top
type zeroGradient;
DuneField
value uniform (0 0 0);
uniformValue constant (0 0 0);
k is as follows
internalField uniform $turbulentKE;
boundaryField
outlet
type inletOutlet;
inletValue uniform $turbulentKE;
inlet
type atmBoundaryLayerInletK;
top
type kqRWallFunction;
value uniform 0.375;
DuneField
type zeroGradient;
nut is as follows
boundaryField
inlet
type nutLowReWallFunction;
value uniform 0.0;
outlet
value uniform 0;
top
value uniform 0;
DuneField
z0 0.03;
value uniform 0;
epsilon is as follows
dimensions [0 2 -3 0 0 0 0];
internalField uniform $turbulentEpsilon;
boundaryField
inlet
type fixedValue;
value uniform 0.01;
outlet
type inletOutlet;
inletValue uniform $turbulentEpsilon;
top
type epsilonWallFunction;
value uniform 0.01;
DuneField
type zeroGradient;
Thank you very much for looking at this
Old   October 24, 2021, 10:03
Hosam Alrefaie
HosamAlrefaie is on a distinguished road
Hi CfdUser5855,
have you solved this?
HosamAlrefaie is offline   Reply With Quote
Old   January 29, 2022, 20:57
sunafegon is on a distinguished road
Hi everyone,
I've encountered this issue as well. Has anyone found a solution?
Much appreciated.
sunafegon is offline   Reply With Quote
Old   January 30, 2022, 10:40
Bloerb will become famous soon enough
Check your polyMesh boundary file. Make sure that walls are of type wall and not patch.
Bloerb is offline   Reply With Quote
Old   January 30, 2022, 11:56
Hi Bloerb, I think that aspect of the issue has already been solved. It's now turned to the issue of it demanding that the inlet and outlet patches be of type wall instead of type patch, which isn't correct for the study type. I'm not sure if it makes a difference to the calculation, however. Maybe it doesn't matter if the inlet or outlet are type patch or type wall given the equations used to define the conditions. Any thoughts?
Thanks.
Old   July 11, 2023, 12:40
Albrecht vBoetticher
vonboett is on a distinguished road
I had the same problem... so here is the simple solution:
just still use:
type calculated; value uniform 0.0
for a patch and wallFunctions for walls.
vonboett is offline   Reply With Quote
pimplefoam, turbulent
natural convection in square cavity having inlet and outlet sujeet OpenFOAM Running, Solving & CFD 1 November 2, 2019 02:17
time step continuity error increases with time_SRFSimplefoam mostafa kamal OpenFOAM Running, Solving & CFD 7 October 2, 2019 02:00
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 02:41
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 06:00
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
