what is useUserTime flag in function objects? |
December 21, 2023, 14:57 |
ONESP-RO
Rep Power: 5 |
In function objects, there is a flag 'useUserTime'. Could you please explain what does thid flag do? what is its purpose? Any examples to clarify this are appreciated. Regards
Don't keep making the same mistakes. Try to make new mistakes. |
January 4, 2024, 03:52 |
Mark Olesen
Rep Power: 40 |
Did you already read the documentation note on writeFile.H ?
January 4, 2024, 04:30 |
Rep Power: 14 |
This may save you some time in the future, and allow you to avoid pointless posts .
1. Open up Doxygen (you are using the ESI version, I think, so that would be https://www.openfoam.com/documentati...doc/index.html). 2. Type in the thing that you are searching for in the search box, i.e. useUserTime here; if it finds the search item, a drop down of hyperlink(s) will appear with all items starting with your string - click on the appropriate one 3. this will open up the Doxygen pages for the thing you are searching for. In other words, within just a few seconds you would get: Code:
bool useUserTime_ protected Flag to use the specified user time, e.g. CA deg instead of seconds. Default = true Definition at line 152 of file writeFile.H. Doxygen can be a bit clunky sometimes, but is your key to unlocking the mysteries of OF! Good luck and Happy New Year! |
January 4, 2024, 04:41 |
#4 | |
ONESP-RO
Rep Power: 5 |
But the description does not make sense for me at all. The short description says: "... to use the specified user time..": What is a user time? how can I specify it? Also in the description: "CA deg instead of seconds": What is CA deg????? You can see clearly that this description does not make sense without context, that's why I have asked for clarification and examples. Best regards
January 4, 2024, 04:43 |
ONESP-RO
Rep Power: 5 |
Thank you for your reply. Yes, I have checked the documentation, but unfortunately it is not clear. An example showing how to use this flag in practice would be much helpful.
Thank you.
January 4, 2024, 05:03 |
Rep Power: 14 |
Aaah - well, now that's a much better question. "CA" stands for crank angle and comes from the development of engineFoam I believe (correct me Mark if I am wrong).
The userTime is whatever you want it to be ... it suggests degrees in the header, but it could be anything. To see what the useUserTime flag does, take a look at writeFile.C, where you'll see: Code:
if (useUserTime_) { timeValue = fileObr_.time().timeToUserTime(timeValue); } const word timeName = Time::timeName(timeValue); If you really want to dig into it, I suggest starting with https://www.openfoam.com/documentati...9ee65af8a.html ... and in particular https://www.openfoam.com/documentati...8C_source.html where you'll see the above being implemented. I found this pretty quickly with a command line grep command. Good luck again. |
January 4, 2024, 06:01 |
#7 | |
ONESP-RO
Rep Power: 5 |
Nice explanation Assuming that I understand that and it does what I think it does, I wonder how I can use this in my simulations. Is there a minimal tutorial where this is used? can I use it with pimpleFoam? how?
January 4, 2024, 07:01 |
Rep Power: 14 |
No - I don't think so - it's a much more fundamental feature, and you would have to build it into a bespoke solver, including your own definition of the time class etc. This probably means redefining a whole bunch of classes ... but that's just speculation on my part, I haven't researched it fully. The engineFoam solver that I pointed you to gives you an idea of the effort involved.
Error in enabling the python wrapper | Jinn | SU2 Installation | 2 | April 23, 2022 13:52 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
