interfaceCompression not well implemented for phaseScalarTransport?
Old   January 3, 2024, 05:38
Default interfaceCompression not well implemented for phaseScalarTransport?
Folmer
Folmer is on a distinguished road
I try to run a modified tutorial DTCHullMoving with added phaseScalarTransport.
Before running the case I set s.water to 1 in a certain region using setFields.
After starting foamRun (openfoam 11) I get the following error:
--> FOAM FATAL ERROR:
Not implemented
From function virtual Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::interfaceCompressionNew::weights(const volScalarField&) const
in file interfaceCompression/interfaceCompression.H at line 127.
FOAM aborting
Modification of the controlDict:
functions
  s
    type            phaseScalarTransport;
    libs            ("libsolverFunctionObjects.so");
    field           s.water;
Addition under divSchemes in fvSchemes:
    div(alphaPhi.water,s.water)     Gauss interfaceCompression vanLeer 1;
Addition in fvSolution:
    "s.*"
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0;
        minIter	     1;
Furthermore I added the file s.water in the 0 folder.
Is the phaseScalarTransport not implemented? Is there a workaround?
I would like to simulate the transport of a scalar in the alpha.water phase using interfaceCompression (no diffusion).
Pease can anyone help me?
Folmer is offline   Reply With Quote
incompressiblevof, interfacecompression, phasescalartransport
Confusion about how the implicit coupled interfaces are implemented? chengdi OpenFOAM Programming & Development 2 April 18, 2019 01:20
What is scAlpha vs. icAlpha vs interfaceCompression amh@inventas.no OpenFOAM Running, Solving & CFD 0 October 4, 2018 05:11
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
rhoSimplecFoam - which algorithm is implemented - references Manuel CFD OpenFOAM Programming & Development 7 September 8, 2014 07:28
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
