noSlip BC for rhoCentralFoam
Old   July 7, 2022, 17:40
Exclamation noSlip BC for rhoCentralFoam
Gurjot Ahuja
tum-student is on a distinguished road
I am simulating a diamond airfoil at supersonic flow at Mach 3. I am using rhoCentralFoam as a solver and k-w SST turbulence model to solve this case. When I use velocity boundary condition as "slip" for the airfoil boundary, my run is successful without any problems, but when I change the BC to "noSlip". I am getting a "Negative Initial Temperature T0" error and the run crashes.
I have also tried to limit the temperature using fvOptions, but it's not working. I have also checked by refining the mesh, but still, the problem exists.
Please help me.
Other boundary conditions for airfoil are as follows:
p - type zeroGradient
T - type zeroGradient
alphat - type compressible::alphatWallFunction, value uniform 8.88e-9
epsilon - type epsilonWallFunction, value uniform 365627.58
k - type kqRWallFunction, value uniform 901.31
nut - type nutkWallFunction, value uniform 0.199
omega - type omegaWallFunction, value uniform 4507.4
tum-student is offline   Reply With Quote
Old   January 23, 2024, 19:50
chc
chc is on a distinguished road
Have you had any luck in solving this issue? I keep getting those negative Temperature errors, however, after a few tenths of a second in the simulation. Thank you.
chc is offline   Reply With Quote
airfoil, negative temperature, noslip, rhocentralfoam, viscous flow
Openfoam Turbulent Car Simulation meganrw OpenFOAM Running, Solving & CFD 0 July 5, 2021 15:50
Wall Conditions : fixedValue or noSlip Magistrane OpenFOAM Running, Solving & CFD 4 September 28, 2020 06:55
ACMI rotating zone: which frame is used for fixedValue, noSlip, movingWallVelocity? zommuter OpenFOAM Running, Solving & CFD 0 September 2, 2020 03:13
Problem with boundary layer - noSlip condition not being respected - OpenFOAM heitorvitorc OpenFOAM Post-Processing 1 August 14, 2019 05:14
multiphaseEulerFoam/tank discharge ves OpenFOAM Running, Solving & CFD 8 December 31, 2017 14:59
