Boundary conditions - rarefied gas flow in pipe
Old   February 2, 2024, 08:02
Default Boundary conditions - rarefied gas flow in pipe
Maxwell-Smoluchowski is on a distinguished road
I am trying to simulate the pressure-driven flow of rarefied gas through a circular pipe with the rhoCentralFoam solver (OF 2306). Of the data I have the type of the gas, values of pressure at the inlet and outlet of the pipe, value of mass flow rate through pipe, value of temperature at the wall and value of temperature at the inlet of pipe.
Somehow I cannot run the simulation and I think that I have a problem with boundary conditions and with mapping the data I have to OpenFoam BC. I checked wedge mesh with checkMesh and it says the mesh is OK. I've tried multiple options for boundary conditions. I am using maxwellSlipU BC for velocity at the wall and smoluchowskiJumpT for temperature at the wall. Temperature and velocity at the outlet are defined as zeroGradient. Temperature at the inlet is fixedValue. For the velocity and pressure I've tried different combinations (for inlet: pressure zeroGradient, velocity fixedValue; pressure totalPressure, velocity pressureInletVelocity; pressure zeroGradient, velocity flowRateInletVelocity)
My case is attached here https://we.tl/t-Ts69BLzwFJ
Maxwell-Smoluchowski is offline   Reply With Quote
pressure driven, rarefaction, rarefied flows, rhocentralfoam, slip b.c.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
