Solve continuity equation for one dimensional mesh motion velocity. Need derivative i |
February 5, 2024, 11:30 |
Solve continuity equation for one dimensional mesh motion velocity. ddz derivative
Rep Power: 2 |
Hello everyone,
I am trying to model a fluid to solid phase change with mesh motion caused by the phase change. Now the Mesh deforms with the velocity , but only in z direction. Therefore it should be mathematically possible to solve the following continuity equation for : where = volume fraction of solid = density of liquid solution = density of solid = fluid velocity without Mesh velocity Now I can not solve this scalar Equation for a vector, but since only the z-component of can be non-zero, I can write it like this: Mathematically that should make sense, but I lack the OpenFoam tools and knowledge to solve this in my program. Since there is no fvm::ddz method. I know that I can get the derivation of the z-component in the z direction by using: Code:
volScalarField Umz = Um.component(2); volVectorField gradUmz = fvc::grad(Umz); volScalarField gradUmzz = gradUmz.component(2); What I also tried was defining an alphaz vector field, which is 0 in his x and y component and has the alpha values in the z component. I calculated the dot product with the face normals, the same way phi gets calculated, to get a surfaceScalarField, and tried to solve for Umz. This is how it looks: Code:
forAll(alphaz,i) { alphaz[i].component(2) = alphaice[i]; } forAll(alphaz.boundaryField(), patchI) { forAll(alphaz.boundaryField()[patchI], faceI) { alphaz.boundaryFieldRef()[patchI][faceI].component(2) = alphaice.boundaryField()[patchI][faceI]; } } surfaceScalarField surfacealphaz ( IOobject ( "phialphaz", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), linearInterpolate(alphaz) & mesh.Sf() ); tmp<fvScalarMatrix> tUmEqn ( fvc::ddt(rhomix,alphawater) + rhoice*fvc::ddt(alphaice) + fvc::div(rhomixUrel) + rhoice*fvm::div(surfacealphaz,Umz) ); #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Fie I suppose my method is not very physical, hence a lot of problems occurr. If anyone knows, how to incorporate a derivative in only one direction of space in the solver Matrix, that would be great. Any help would be appreciated. Thank you Last edited by danylo; February 6, 2024 at 03:17. |
February 13, 2024, 05:09 |
Any ideas?
Rep Power: 2 |
Does anyone have any idea how i could solve this issue? I did not make any progress yet
Thank you |
February 22, 2024, 05:01 |
Rep Power: 2 |
Update:
I can get the code for the alphaz surfaceScalarField to run but I get nonsense values. Problem was that alphaice was 0 at the start, and so it was impossible to solve for Um. I set alphaice to a small starting value, but the value Um just spirals out of control up to extremely high values. |
continuity, differentiation, equation, onedimension, solve error |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
continuity equation | Rafal | Main CFD Forum | 4 | November 29, 2006 09:27 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
