How to set the radiationProperties for transparent solid material
Like Tree1Likes
  • 1 Post By Alczem
Old   February 21, 2024, 08:18
Default How to set the radiationProperties for transparent solid material
LIYAFEI
LIYAFEI is on a distinguished road
Dear CFDer
I'm trying to use openfoamV11 (foundation edition) to simulate PVD reactor,
The highest temperature in the case is around 2000 degree. So I need to use the radiation model. Now I use the fvDOM method to simulate the radiation.
But for the solid material, I have nontransparent graphite and transparent quartz.
So I want to know how to set these two material?
The default setting for the solid is as following
radiation on;
radiationModel opaqueSolid;
absorptionEmissionModel constant;
absorptivity absorptivity [0 -1 0 0 0 0 0] 0.01;
emissivity emissivity [0 -1 0 0 0 0 0] 0.2;
E E [1 -1 -3 0 0 0 0] 0;
scatterModel none;
sootModel none;
Should I also set the radiationProperties of the transparent quartz the same with air?
thank you
LI
LIYAFEI is offline   Reply With Quote
Old   February 23, 2024, 03:18
Alczem is on a distinguished road
Hey!
Transparent medium is not implemented currently, only transparent boundaries.
I tried several workarounds to achieve the same thing you are doing, but the main issue is that the radiative fields are not communicating between two regions of a CHT case.
Good luck to you, and if you do manage to find a solution, please share it, it is a feature I would love to see implemented!
Alczem is offline   Reply With Quote
Old   February 23, 2024, 03:38
LIYAFEI
Thank you for your reply.
The following are the boundary conditions I set.
type greyDiffusiveRadiation;
value uniform 0;
emissivityMode solidRadiation;
emissivity uniform 1;
So, as you said, the emissivity of the gas-solid interface (transparent solid) is 0, and the emissivity of the gas-solid interface (completely opaque) is 1, is that right?
Originally Posted by Alczem View Post
Hey!
Old   February 26, 2024, 05:45
Yep, but OpenFOAM does not compute a radiative field inside solid regions, so whatever you set at the boundary, the radiation will be converted to heat conduction inside the solids.
I tried to use a fluid region with frozen flow on, but there is not only one radiative field, each region has its own. Meaning that an incident ray from region 1 will hit the interface between region 1 and region 2, and its angle of incidence won't matter when region 2 will compute radiation, the radiation from region 1 will be re-computed according to the boundary properties for region 2, if that makes sense...
LIYAFEI likes this.
Old   February 26, 2024, 06:53
LIYAFEI
Thank you
But Can I use fvDOM model for solids?
openfoam 11, radiation properties, transparent solid
Adding material to CFX material library marlon CFX 2 October 16, 2016 09:33
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
