Problem with DynamicMeshDict -TopoChange in parallel
Old   March 21, 2024, 11:29
Default Problem with DynamicMeshDict -TopoChange in parallel
thr
thr
thr is on a distinguished road
i have a problem with OpenFoam 11 and dynamic mesh refinement.
I simulate a mulitphase sloshing case and try to use topochanger in dynamicMeshDict.
I get the following warning and then an error i have never seen before.
Do you understand the warning or the error?
Did anybody have the same problem?
--> FOAM Warning :
From function static void Foam::hierarchGeomDecomp::findBinary(Foam::label, const Foam::List<double>&, const Foam::List<double>&, Foam::label, Foam::scalar, Foam::scalar, Foam::scalar, Foam::label&, Foam::scalar&)
in file hierarchGeomDecomp/hierarchGeomDecomp.C at line 316
unable to find desired decomposition split, making do!
[90] --> FOAM FATAL ERROR:
[90] cell 243 of level 1 does not seem to have 8 points of equal or lower level
cellPoints:8(83 85 95 99 156 413 478 479)
pointLevels:8(1 1 1 1 1 1 2 2)
[90]
[90]
[90] From function Foam::labelListList Foam::hexRef8::setRefinement(const labelList&, Foam:olyTopoChange&)
[90] in file polyTopoChange/polyTopoChange/hexRef8/hexRef8.C at line 3678.
[90]
FOAM parallel run aborting
thr is offline   Reply With Quote
parallel simulation problem alvarolltsz OpenFOAM Running, Solving & CFD 1 March 4, 2024 06:35
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
damBreak case parallel run problem behzad-cfd OpenFOAM Running, Solving & CFD 5 August 2, 2015 17:18
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 19, 2015 23:41
