symbol lookup error: /lib/libsolidSpecie.so: undefined symbol
Old   March 24, 2024, 17:55
Default symbol lookup error: /lib/libsolidSpecie.so: undefined symbol
liltunizplaya is on a distinguished road
Hey guys, I'm trying to run this the moving_cylinder tutorial from wolfdynamics:
http://www.wolfdynamics.com/tutorials.html?id=142
the last step in the tutorial is to run the solver by using
mpirun -np 4 overPimpleDyMFoam -parallel
but unfortunately i get this error everytime i run one of the tutorials..
overPimpleDyMFoam: symbol lookup error: /lib/libsolidSpecie.so: undefined symbol: _ZN4Foam8fileName20allowSpaceInFileNameE
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[5331,1],0]
  Exit code:    127
did someone have this problem before? i tried the tutorials with openfoam 10 and 9 both have the same issue.
can you guys help me?
liltunizplaya is offline   Reply With Quote
Old   March 25, 2024, 13:44
Shravan
Severus is on a distinguished road
You usually get this error when there is a mistake in the Make/options file.
See here: Undefined symbol error after compiling a new LES model
Thanks
Severus is offline   Reply With Quote
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
