How to stop the oversetMesh from leaving the main domain |
April 1, 2024, 13:16 |
Rep Power: 3 |
Hello!
I am trying to simulate something like a stone falling down in a vessel. I use OF v2312, oversetMesh and sixDoFRigidBodyMotion without any constraints and restraints (because I want the solid object to move according to the flow). I include the libs (overset fvMotionSolvers) in the controlDict file. But the problem is that the object falls down and leaves the main domain. How can I make it "feel" there is a bottom? Maybe I should include some restraints, but I don't know what exactly. I have another issue, which is related to the complex geometry of the main vessel. I use the adjustTimeStep and maxCo options, but the result is a very huge Courant Number and very small deltaT - smaller than 1e-20 or 1e-30. Is there any possibility to fix this besides making finer mesh, which would probably lead to very small deltaT again? I would highly appreciate any advice! Best regards! |
April 2, 2024, 10:21 |
Rep Power: 5 |
Hey!
Without going as far as modelling proper impact, there is a constraint that acts as a soft wall: https://www.openfoam.com/news/main-n...sics#soft-wall Maybe it can suit your needs! |
April 3, 2024, 04:29 |
Rep Power: 3 |
Thank you very much for your reply, Alczem! It really suits my case and helped me a lot! The only problem now is that whenever the object reaches the bottom, this leads to error and the simulation stops. Maybe I did not use proper values for psi and C (first I used 0 for both). Actually, I tried different values, but then it behaved very strange - the object goes far away outside the domain in the side and upper direction for example. Do you have any recommendations for these parameters?
Thanks a lot again and best regards! |
April 3, 2024, 04:56 |
Rep Power: 5 |
I never used it myself, but you can check out the source code of the constraint. There we can see this:
{ restraintPosition = motion.transform(refAttachmentPt_); restraintForce = Zero; restraintMoment = Zero; const vector r(restraintPosition - anchor_); const vector v(motion.velocity(restraintPosition)); const scalar d = (wallNormal_/mag(wallNormal_)) & r; const vector rDir(r/(mag(r) + VSMALL)); const scalar m = motion.mass(); const scalar wn = 3.14/C_; const scalar damping = psi_*2*wn*m; const scalar stiffness = sqr(wn)*m; if (d < 0) { restraintForce = (-damping*(rDir & v) + stiffness*d)*rDir; restraintMoment = restraintPosition^restraintForce; } if (motion.report()) { Info<< " restraintPosition: " << restraintPosition << " restraintForce: " << restraintForce << " restraintMoment: " << restraintMoment << endl; } } It also seems to me that the anchor point should be away from the wall you want to avoid, in order to let d become negative. For instance, if your "ground" is at z=0m, maybe have the anchor at z=0.5m and wallNormal should be (0,0,1). I don't know how you first set up the constraint, but that is my interpretation of the code. |
April 4, 2024, 06:58 |
Rep Power: 3 |
Yes, I will try to calculate some reasonable values. Тhank you very much for your help and advices!
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 11:16 |
Can CFX model periodic heat transfer problem | Ethan_Sparkle | CFX | 41 | June 14, 2017 07:22 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 06:58 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 01:54 |
