conservation of energy in VIV
Old   April 4, 2024, 10:51
Default conservation of energy in VIV
ROIN bin
Beingzzz is on a distinguished road
hello everyone,
I recently used pimplefoam to calculate vortex-induced vibration to verify the energy conservation of the flow field. I understand that the equations of incompressible flow require only the conservation of mass and momentum, because the temperature field does not change with time, and naturally satisfies the conservation of energy. But strangely enough, I output the flux of the following formula and find that there is no way to conserved it(see Attach Files).
My simplified energy conservation equation is this: the power of the shear stress and surface pressure is equal to the rate of change of kinetic energy of the flow field and the boundary momentum flux. That's item 2,4,5 in the picture. However, the output results are not quite the same, and the kinetic energy change rate of the flow field is much higher than other terms. Does anyone have any experience with that? Thank you very much. (Please remind me if you need other materials)
Beingzzz is offline   Reply With Quote
energy pimplefoam viv
Question about the energy conservation in interFoam zhaohb11_cfd OpenFOAM 2 February 1, 2023 09:59
What is this conservation of energy mouli1991 Main CFD Forum 2 September 26, 2013 20:33
Kinetic Energy Conservation longamon OpenFOAM Running, Solving & CFD 1 May 28, 2011 02:08
Coal deomposition and conservation of energy vejahati FLUENT 0 May 27, 2011 12:51
Energy conservation issue izumi11 FLUENT 0 May 10, 2010 01:05
