July 4, 2020, 13:06 |
Calculating Density in ParaView
Ahsan
Rep Power: 6 |
Dear Users,
Can someone please help with how to get the density in ParaView? I am using interMixingFoam solver of OpenFOAM, and the parameters I get after the run are p, p_rgh, U, alpha.water, alpha.air, alpha.other, nut, nuTilda... but there is no rho for the density... I want to have a density profile since my density in the domain changes as two fluids mix together. Can I get it somehow? Is there a way to achieve that? I tried to use the calculator filter with (p-p_rgh)/(9.81*coordsZ) but this gives huge values at the bottom of the domain, probably due to a "zero" in the denominator... can someone please help me with this issue...? Thanks a lot in advance Have a good day!!! |
July 20, 2020, 19:43 |
Joachim Herb
Rep Power: 21 |
You should be able to write rho with a writeObjects function object: https://www.openfoam.com/documentati...teObjects.html
May 27, 2021, 08:50 |
Alternate and faster solution
#3 | |
Ahsan
Rep Power: 6 |
Thank you for your reply. However, what you suggested would need the simulation to start over again. There exist another option: Once you have run the OpenFOAM simulation, just open it in ParaView and apply the calculator filter like this (-p+p_rgh)/(9.81*(CoordZ)) and this will give you the density for the whole domain. |
May 28, 2021, 10:13 |
#4 | |
Rep Power: 14 |
someFoamSolver -postProcess -latestTime -func "writeObjects(h, rho)" |
May 6, 2024, 11:16 |
Tariq Ridwan
Rep Power: 12 |
Are you using an incompressible solver?
tariqridwan.github.io/ |
density, filter, openfoam, paraview, pressure |
[General] Calculating transpose of a tensor in Paraview | Giri_24 | ParaView | 0 | April 13, 2020 23:13 |
UDF for modifying density of mixture phase during the calculating process | sola86 | Fluent UDF and Scheme Programming | 2 | May 28, 2019 09:24 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 14:20 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
