Model the reaction of gases to form solid product |
May 2, 2024, 05:30 |
Johannes
Rep Power: 3 |
Good day,
I have a reacting gas mixture and rhoReactingFoam is serving me well in this regard. However, consider the case of a reaction between two gas species to form a product in its solid state. It can be represented by X(gas) + Y(gas) -> Z(solid). I would like to avoid the Lagrangian approach, as I have a different method to account for the particle phase. The particle phase is non-inertial and follows the velocity field of the gas mixture. The trouble I have is that the Thermophysical setup for a reacting mixture only allows a single model that is applied to all species. If I could, I would like to take species Z(solid) and fix its density, instead of having it solved with the ideal gas equation of state like the rest of the species. Let's say Z(solid) makes up 20% of the mass flow, using the equation of state to calculate its density will lead to an incorrect volume flow rate and subsequent velocity field for the mixture. Is anyone aware of an existing approach in openFOAM to model this phenomenon? |
May 12, 2024, 14:36 |
Johannes
Rep Power: 3 |
The approach I was looking for turns out to be the multiphase approach, and I am busy modifying one of the existing solvers for my problem.
Conjugate Heat Transfer: Solid Time Step in Transient Simulation, DO Model | Dingens | FLUENT | 0 | July 9, 2021 06:19 |
How to define a reaction between a porous solid (not a catalyst) and gas | yijecho | FLUENT | 4 | November 30, 2020 23:13 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
How to create extrude solid model from other extrude solid model | nizam | Structural Mechanics | 0 | April 13, 2015 18:51 |
