Calculating Density in ParaView
Like Tree5Likes
  • 2 Post By jherb
  • 1 Post By mahsankhan
  • 2 Post By Tobermory
Old   July 4, 2020, 13:06
Question Calculating Density in ParaView
Ahsan
mahsankhan is on a distinguished road
Dear Users,
Can someone please help with how to get the density in ParaView?
I am using interMixingFoam solver of OpenFOAM, and the parameters I get after the run are p, p_rgh, U, alpha.water, alpha.air, alpha.other, nut, nuTilda... but there is no rho for the density...
I want to have a density profile since my density in the domain changes as two fluids mix together. Can I get it somehow? Is there a way to achieve that?
I tried to use the calculator filter with (p-p_rgh)/(9.81*coordsZ) but this gives huge values at the bottom of the domain, probably due to a "zero" in the denominator... can someone please help me with this issue...?
Thanks a lot in advance
Have a good day!!!
mahsankhan is offline   Reply With Quote
Old   July 20, 2020, 19:43
Joachim Herb
jherb is on a distinguished road
You should be able to write rho with a writeObjects function object: https://www.openfoam.com/documentati...teObjects.html
dlahaye and mahsankhan like this.
jherb is offline   Reply With Quote
Old   May 27, 2021, 08:50
Smile Alternate and faster solution
Ahsan
Thank you for your reply.
However, what you suggested would need the simulation to start over again. There exist another option:
Once you have run the OpenFOAM simulation, just open it in ParaView and apply the calculator filter like this (-p+p_rgh)/(9.81*(CoordZ)) and this will give you the density for the whole domain.
tariq likes this.
Old   May 28, 2021, 10:13
Tobermory will become famous soon enough
No - you misunderstood jherb - just run the solver with the -postProcess flag and the writeObjects func, and it will spit out the field for you without running any more of the simulation. Eg.:
someFoamSolver -postProcess -latestTime -func "writeObjects(h, rho)"
jherb and Balzuka like this.
Tobermory is offline   Reply With Quote
Old   May 6, 2024, 11:16
tariq's Avatar
Tariq Ridwan
tariq is on a distinguished road
Are you using an incompressible solver?
tariqridwan.github.io/
tariq is offline   Reply With Quote
density, filter, openfoam, paraview, pressure
[General] Calculating transpose of a tensor in Paraview Giri_24 ParaView 0 April 13, 2020 23:13
UDF for modifying density of mixture phase during the calculating process sola86 Fluent UDF and Scheme Programming 2 May 28, 2019 09:24
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
