Negative initial temperature T0: -1.44502 while running chtMultiRegionFoam |
August 9, 2023, 05:19 |
sachin
Rep Power: 3 |
I am trying to run Numerical Simulation of Battery Cooling system using OpenFOAM-V11. There are 3 cases for this simulation. Case 1 was creating the mesh and in Case 2 we will be applying the thermo physical properties. I was able to generate the mesh and I am facing some problem while running case-2. I am facing this error while running the chtMultiRegionFoam solver --> FOAM FATAL ERROR: Negative initial temperature T0: -1.44502 From function static Foam::scalar Foam::species::thermo<Thermo, Type>::T(const ThermoType&, Foam::scalar, Foam::scalar, Foam::scalar, FType, dFdTType, LimitType, bool) [with ThermoType = Foam::species::thermo<Foam::eConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleInternalEnergy>; FType = double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double, double) const; dFdTType = double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double, double) const; LimitType = double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double) const; Thermo = Foam::eConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double] in file /home/user/OpenFOAM-11/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 300. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 double Foam::species::thermo<Foam::eConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleInternalEnergy>::T<Foam::species::th ermo<Foam::eConstThermo<Foam::rhoConst<Foam::speci e> >, Foam::sensibleInternalEnergy>, double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double, double) const, double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double, double) const, double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double) const>(Foam::species::thermo<Foam::eConstThermo<Fo am::rhoConst<Foam::specie> >, Foam::sensibleInternalEnergy> const&, double, double, double, double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double, double) const, double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double, double) const, double (Foam::eConstThermo<Foam::rhoConst<Foam::specie> >::*)(double) const, bool) at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo::composite, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::eConstThermo<Foam::rhoConst<Foam: :specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 virtual thunk to Foam::heRhoThermo<Foam::rhoThermo::composite, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::eConstThermo<Foam::rhoConst<Foam: :specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 Foam::solvers::fluid::thermophysicalPredictor() at ??:? #6 ? in "/home/user/OpenFOAM-11/platforms/linux64GccDPInt32Opt/bin/foamMultiRun" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/home/user/OpenFOAM-11/platforms/linux64GccDPInt32Opt/bin/foamMultiRun" My solver is running for a while and then it throws this error! I have attached my whole sample here: case2-proper.zip Would be helpful If someone let me know where I am going wrong! Thanks in advance! h1 { margin-top: 0.71cm; margin-bottom: 0.21cm; direction: ltr; font-size: 20pt; line-height: 100%; text-align: left; page-break-inside: avoid; orphans: 2; widows: 2; background: transparent; page-break-after: avoid }p { margin-bottom: 0.25cm; line-height: 115%; background: transparent }a:link { color: #000080; so-language: zxx; text-decoration: underline } |
March 4, 2024, 20:19 |
Shubham
Rep Power: 2 |
I am encountering a similar problem of a negative temperature. Will you please help me. |
May 7, 2024, 03:51 |
Same problem
Kristine
Rep Power: 2 |
Hi!
Did any of you manage to solve the problem? I'm facing the same problem. |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 17:45 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
