New Wave BC bContinuousb over the Interface for OF 141
Old   March 6, 2008, 07:20
Default Hi Foamers I have made a bo
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Foamers
I have made a boundary condition to be used within the multiphase solvers. At present I have only used it with InterFoam, but I cannot see any problem in applying it with rasInterFoam or lesInterFoam.
The BC generates Stokes 1st order waves on a vertical boundary - though easily extended to any higher order wave theories. The key difference from those BCs previously posted is that the faces at the boundary patch is evaluated each and every one. If a face intersects the interface at the boundary, then the wet and dry areas are determined, and a weighting of the boundary condition above and below the surface is given to that specific face. The reason for this extension is that the other procedure gave me problems with noise generated at the boundary if WET/DRY was only evaluated based on whether the center of the face was above or below the surface. This smoother approach seems to eliminate that.
I am in the middle of making a small technical note, which will be posted her, as soon it is done, but I thought I would like to share with all of you. The technical note will include a small verification and documentation of the chosen procedure together with verification of the BC against available experimental data.
The boundary conditions can be found by following this link:
http://www.student.dtu.dk/~s001581/f...BasedBC.tar.gz
and an example of the use can be found here:
http://www.student.dtu.dk/~s001581/testExample.tar.gz
Any comments will be appreciated Have fun,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   March 6, 2008, 14:34
Default Niels- Thanks for sharing y
Kevin Maki
kjmaki is on a distinguished road
Niels-
Thanks for sharing your new boundary conditions. I am trying to use them on your test case, but I am having some difficulties.
I unpacked your files and ran the Allwmake script. It executes smoothly, and the *so files are placed in my $FOAM_LIBBIN.
When I execute interFoam, I get the following response:
--> FOAM FATAL ERROR :
gradientInternalCoeffs cannot be called for a defaultFvPatchField (actual type surfaceWaveVelocity)
on patch inlet of field U in file "/k/kjmaki/OpenFOAM/kjmaki-1.4.1-dev/run/testExample/0/U"
You are probably trying to solve for a field with a default boundary condition.
From function defaultFvPatchField<type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/default/defaultFvPatchField.C at line 694.
FOAM exiting
If I switch disallowDefaultFvPatchField to 1 in my ~/.OpenFOAM-1.4.1-dev/controlDict, it informs me that surfaceWavePressure is an unknown patchField type.
I have searched the Message Board, and I have found numerous posts that deal with related problems. Unfortunately, none of them were descriptive enough for me to understand exactly how to ensure interFoam will recognize the new conditions.
Thanks for the help!
Kevin
kjmaki is offline   Reply With Quote
Old   March 6, 2008, 15:17
Default Hi Kevin Good to hear that
ngj
Hi Kevin
Good to hear that you can use it.
You have to recompile InterFoam, so it links to the new libraries. Look in the file
OpenFOAM/OpenFOAM-1.4.1/applications/solvers/multiphase/interFoam/Make/options
and add the libraries in the same fashion as "-lfiniteVolume".
The libsurfaceWaveGammaFvPatchField.so does not need to be linked to interFoam as it is not used .. I never managed to get a robust method, where gamma was given as a Dirichlet, thus it is just set to zeroGradient in /0/gamma. The files are just left in the directory for completeness, if any of you come of with a clever idea
I forgot to write, that my test example is rather large - 4 hours run in parallel on 3 cpus - so you might consider to look at the number of cells. I just gave a test, which I used for my verification - details on that to follow.
Further it could be difficult to use the BC on anything but rectangular faces on the boundary patch, where the faces is aligned with the y-z axes. This is due to a minor part of the method, which hasn't been implemented yet - when that is done arbitrary polygons can be used. This addition will come together with the technical note.
Have fun,
Niels
Old   March 10, 2008, 05:06
Default Hi Niels, Thank you for pos
yann Delaure
yann_delaure is on a distinguished road
Hi Niels,
Thank you for posting your BCs.
I have one comment and and one question.
It seems that OpenFoam recommends that new boundary conditions be compiled as new user dynamic library (for example as "libmyBCs.so") by using the following compilation line in the Make/files file: LIB = $(FOAM_LIBBIN)/libmyBCs. The library can then be accessed simply by including the following line at the end of the case/system/controDict:
libs ("libmyBCs.so")
In this way the OpenFoam source code is not modified.
My question concerns the contructor of your boundary condition. You are using the environmentalProperties dictionary. It seems that this dictionary is not loaded when the setFields and decomposePart utilities are run. So when I try to initialise the fields using setFields I get the following errors:
Exec : setFields . testExample
Date : Mar 10 2008
Time : 09:44:50
Host : CARNOT6
PID : 10012
Root : /home/delaurey/OpenFOAM/delaurey-1.4.1/run/tutorials/interFoam/VOF_Apps
Case : testExample
Nprocs : 1
Create time
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
Setting volScalarField gamma
Setting volVectorField U
request for dictionary environmentalProperties from objectRegistry region0 failed
available objects of type dictionary are
3
fvSolution
fvSchemes
setFieldsDict
Reading the gamma field does not generate any error since I use like you a zeroGradient boundary condition. But executation terminates with the initialisation of U. Did you experience similar difficulties?
Thanks
Yann
yann_delaure is offline   Reply With Quote
Old   March 10, 2008, 06:03
Default Hi Yann I tried to remove m
ngj
Hi Yann
I tried to remove my BCs from the compilation of interFoam. When I did that I got the same error as yours. Though compiling with the libraries does not seems to give any problems.
I am very new to both OpenFOAM and C++ thus if there is a need to change things in my BCs, I believe we need to get some advise from a more experienced user. The present BCs is actually based on some other FvPatch<type>Field I found in the source.
Best regards,
Niels
Old   March 10, 2008, 07:23
Default Niels, Thanks for your resp
yann Delaure
Niels,
Thanks for your response. I am also just starting using OpenFoam. I also had a look at the BCs class you used to derive your own. One way of avoiding the problem is to remove the BC variable from the environmentalPropeties dictionary and placing them in the 0/U and other initial field definition. For example:
boundaryName
type surfaceWaveVelocity;
inletValue uniform (0 0 0);
value uniform (0 0 0);
depth 1;
seaLevel 1;
and in the contructor:
depth_(readScalar(dict.lookup("depth"))),
instead of reading the environmentalProperties dictionary. Just to check have you had any problem running your case in parallel? I have implemented a similar BC which runs well on a single processor but fails in parallel. Has anyone else experienced similar problems when using dynamic libraries by using the dlopen methd recommended in the last distribution of OpenFoam (by adding libs ("libfoamUser.so" in controlDict)
Regards
Yann
Old   March 11, 2008, 14:21
Default Hi While implementing a sec
ngj
Hi
While implementing a second order stokes, I found that I have made a bug in the pressure gradient.
Corrected version will be uploaded as soon as possible.
Hope you haven't trusted your life on it
- Niels
Old   March 13, 2008, 05:26
Default Niels, I was reading throug
yann Delaure
Niels,
I was reading through your codes and I have a quick question about a line in interfaceWeight.H:
points[fProp[fI]].component(1)
Does this return the value of the first component of the point vector. In your test case, the x axis is aligned with the wave tank and the gravity vector is in the y direction. Doesn't this mean that your test to check that the point is above the elevation of the free surface should be made with regard to component(2).
Have I misunderstood the meaning of the component() function?
Thanks
Yann
Old   March 13, 2008, 06:14
Default Hi Yann The componet() coun
ngj
Hi Yann
The componet() counts from 0, thus 0->x, 1->y and 2->z
Hope ypu have been getting it to work.
- Niels
Old   March 13, 2008, 07:12
Default Niels, Of course, sorry about
yann Delaure
Niels,
Of course, sorry about that.
Yann
Old   March 16, 2008, 14:24
Default Hi The bug has now been cor
  #11
ngj
Hi
The bug has now been corrected and the boundary condition can be found following the link at the top of this thread.
A second order stokes wave has been implemented, which resulted in an additional keyword in the environmental-dictionary, namely waveType. It has to be either StokesFirst or StokesSecond. At second order wavenumber, etc is the same as for first order.
Have fun,
Niels
Old   June 5, 2008, 12:08
Default Hi Niels, I am very keen to
  #12
Charlotte Higgins
chiggins is on a distinguished road
Hi Niels,
I am very keen to look at the boundary conditions you have created but I cant access the link supplied:
Are you able to email it to me?
Cheers
Charlotte
chiggins is offline   Reply With Quote
Old   June 6, 2008, 03:03
Default Hi Charlotte My initials ha
  #13
ngj
Hi Charlotte
My initials have been changed, so please replace "s001581" with "ngja" and you should be able to access the files.
Best regards,
Niels
Old   June 8, 2008, 11:47
Default Hi Charlotte I have ended u
  #14
ngj
Hi Charlotte
I have ended up with setting the velocity in the air to zero in each time step, as discussed in [1] p. 11.
The reason for this is that I never got around to control the air velocities at the inlet. Large and unphysical velocities appear if such means are not taken.
Best regards,
Niels
[1]. http://vtchl.uiuc.edu/~liu19/publications/scour.pdf
Old   October 3, 2008, 06:38
Default Hi I'm new to OpenFoam and
  #15
ben wraight
ben_wraight is on a distinguished road
Hi
I'm new to OpenFoam and i'm having difficulty applying these boundary conditions. Eventually I'd like to place an aerofoil into a wave tank, but initially I'm trying to use a wave tank with a cylinder inside it. I've built the mesh and the tank is producing waves, however the waves are generating from the centre creating 2 sets of waves. Does anyone know why this is happening and how I would go about generating the waves from the left hand side of my tank.
Thanks
Ben
ben_wraight is offline   Reply With Quote
Old   October 3, 2008, 07:19
Default Hi Waves are generated at x
  #16
ngj
Hi
Waves are generated at x=0 at default (a.k.a. hard-coded).
- Niels
Old   October 3, 2008, 07:20
Default Sorry, that does not make sens
  #17
ngj
Sorry, that does not make sense, as internal generation of waves sound pretty weird. You need to elaborate on the problem, otherwise we will not be able to help you.
A screen-dump or similar would be helpful.
- Niels
Old   October 3, 2008, 07:36
Default The screen shot shows how the
  #18
ben wraight
The screen shot shows how the waves are mirrored about x = 0. The mesh I built starts at x = -2. If I rebuild the mesh to start at x = 0, should the waves generate from the far left of my mesh?
file:///home/ben/OpenFOAM/ben-1.5/run/tutorials/interFoam/wavecylinder/wavecylin der/wave.0002.jpg
Thanks
Ben
Old   October 3, 2008, 07:42
Default Sorry, here is the screen h
  #19
ben wraight
http://pichostonline.com/][img]http://pichostonline.com/u/081003/c1f756d531.jpg[/img][/url]
Old   October 3, 2008, 08:40
Default Hi Are you sure, that you h
  #20
ngj
Hi
Are you sure, that you haven't applied the waveBC to a patch internally, as the boundary conditions are applied to a patch and not in the internal part of the domain.
/ Niels
help me for"wave maker"&"wave absorber" bestrcsekhar Main CFD Forum 0 November 28, 2008 04:57
cut wave Julian CFX 1 April 30, 2007 13:36
Wave equation Pratap Main CFD Forum 4 October 20, 2004 23:51
Sin Wave Síle FLUENT 3 May 2, 2003 10:00
Is "Void wave" same as "density wave"??? two phase flow Main CFD Forum 0 April 30, 2003 10:45
