Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Like Tree43Likes
Old   February 6, 2009, 16:29
Default Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam
Jovani L. Favero
jovani is on a distinguished road
Send a message via Skype™ to jovani
Hello Foamers,
My name is Jovani and I want announce that will soon be available a solver for treatment of viscoelastic fluid in OpenFOAM. I was working in the development of a viscoelasticFluidFoam solver (with the great orientation of the Dr. Hrvoje Jasak, thank you very much Hrvoje!!) to simulate viscoelastic flows.
The follow models are implemented: Maxwell, Oldroyd-B, Giesekus, PTT linear and exponential,
FENE-P, FENE-CR and DCPP. There are others models already implemented but not tested (Pom-Pom, SXPP, DXPP, WM ...).
The metodology used to obtain solutions in high We numbers was the DEVSS. The test geometry was mainly the 4:1 planar contraction. The solver are able to simulate multimode cases with n modes.
For the interested: A presentation that will soon be available on line to give more informations.
Jovani
jovani is offline   Reply With Quote
Old   February 6, 2009, 18:43
Default Brilliant work, Jovani! Do
Sandeep Menon
deepsterblue will become famous soon enough
Do you think I could take a look at the sources? This is something we were looking to implement, but it looks like you've saved us the trouble!
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   February 6, 2009, 19:02
Default Hello Menon, Yes, the solve
Jovani L. Favero
Hello Menon,
Yes, the solver will be available in the -dev version of OpenFOAM, but you need wait untill the solver is put into the source. Don't be worried, this will be done soon.
Jovani
Old   February 7, 2009, 10:03
Default Hi Jovani, Great work! This
Kerstin Heinen
kerstin is on a distinguished road
Hi Jovani,
Great work! This will speed up research in viscoelastic simulations a lot. 8-)
Really great!
Greetings
Kerstin
kerstin is offline   Reply With Quote
Old   February 7, 2009, 10:18
Default A piece of propaganda: Jovani
Hrvoje Jasak
hjasak will become famous soon enough
A piece of propaganda: Jovani did this work under a Masters project at Universidade Federal Rio Grande do Sul, Brazil and we are trying to convince him to stay on and do a PhD along similar lines.
Can I ask the audience to kindly help me in this.
Hrv
kk415 and tonnykz like this.
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   February 7, 2009, 11:55
Default Hi Jovani, great job! And t
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
Hi Jovani,
great job! And the fact that it was made under a master's project is simply terrific! Great.
And... You should just listen to Hrvoje! Go on with CFD and do a PhD. So we can wait for more good to come in the field of viscoelastic flow simulations!
best
Holger
alqayssi69 likes this.
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   February 7, 2009, 17:38
Default Thanks everyone!! Thanks Hr
Jovani L. Favero
Thanks everyone!!
Thanks Hrvoje for the propaganda!
Marschall, I'm thinking to a PhD. There are a lot of studies to be done in this area.
As there isn't much in this area into commercial softwares, I think that if we do any efforts, with the help of Hrvoje of course, we can create something top of line.
Jovani
Old   March 4, 2009, 16:08
Default Hello Jovani, Thank you for
Ning Yang
nzy102 is on a distinguished road
Hello Jovani,
Thank you for your good work. When will the next solver be released?
Ning
nzy102 is offline   Reply With Quote
Old   March 5, 2009, 04:46
Default Hi Jovani, that all looks v
max
markus gruber
max is on a distinguished road
Hi Jovani,
that all looks very promising.
However, could you give some details about the stability of your solver:
- up to which We (or De)-Number stable solutions can be obtained in your 4to1 planar geometry?
- any tests on realistic 3-D geometries and if, what is the performance in terms of CPU-time?
cheers Max
max is offline   Reply With Quote
Old   March 5, 2009, 15:59
Default Hello All, Ning, the solver
Jovani L. Favero
Hello All,
Ning, the solver will released in this month or the maximum in April. I believe I will not have time to test some models (white-Metzner and derivations, PP, XPP and Feta-PTT) but their will be into the solver too. Is necessary validate these models.
Max,
About the De numbers: I make any test to explore this question, but only for some models (PTT and Giesekus). But to give to you a number I simulate a case that I simulate was a LDPE flow with De=250 using Giesekus 8-mode model, this was't the limit for this case, I simply don't tried higher values. A complete study to this maximum Deborah values need to be done. Other, the DEVSS methodology sugest an arbitrary value for the the term added to moment equation, generally is used the value of etaP (value that is used in the solver), but we know that the better value for this term is related with each model and your parameters, this need more study too and I think with it's possible obtain any improvements. The interpolation shemes used also afect it.
About 3-D simulations: I do a test with a realistic case that was the flow into a capillary with a contraction. The mesh was about 150000 volumes, considering 2 simetry planes. As is make the transient simulation the Courant number control the time step, but the simulation time is acceptable for me. I used multigrid and parallelization tecniques for it.
file:///home/jovani/Desktop/PresentationSolver/pictures/magtautri2.png
file:///home/jovani/Desktop/PresentationSolver/pictures/meshtri.png
Jovani
Old   March 5, 2009, 16:04
  #11
Jovani L. Favero
Hello All,
Max,
Jovani
Old   March 5, 2009, 19:37
Default Ops, Sorry!!! An error occu
  #12
Jovani L. Favero
Ops, Sorry!!!
An error occurred, I sent twice the same message and the pictures do not is showed. I believe the pictures appears now.
U magnitude:
http://img24.imageshack.us/img24/174/magutri2.png][IMG]http://img24.imageshack.us/img24/174/magutri2.th.png[/IMG][/URL]
Stress magnitude:
http://img6.imageshack.us/img6/6859/magtautri2.png][IMG]http://img6.imageshack.us/img6/6859/magtautri2.th.png[/IMG][/URL]
Mesh:
http://img22.imageshack.us/img22/9122/meshtri.png][IMG]http://img22.imageshack.us/img22/9122/meshtri.th.png[/IMG][/URL]
Jovani
Old   April 8, 2009, 17:30
Michael Bruckner
michaelb is on a distinguished road
Hello Jovani
I am interested in knowing if the solver is released yet.
I also would like to know, before switching to OpenFOAM, if it possible to model two phase flows, one of the phase having specific viscoelastic properties.
Thank you
Mike
michaelb is offline   Reply With Quote
Old   April 9, 2009, 03:12
Kerstin Heinen
Hi Michael,
In principle nothing is impossible in OpenFOAM. ;-)
I guess handling the viscoelastic stresses correctly in the region, where you don't have a sharp interface is the most tricky part...I mean to make it really physical.
But how do you intend to do it, if you don't switch to OpenFOAM? Everything I can imagine to do as alternative (commercial code or own code) will be much more difficult than in OpenFOAM...
Greetings
Kerstin
Old   May 7, 2009, 17:55
Jovani L. Favero
Hello Mike,
Kerstin is rigth about OpenFOAM
The solver was not release yet! I am finishing the tests Hrvoje ask me to do and I need talk with him about it in this days.
About free surface viscoelastic flow: Yes is possible in OpenFOAM, I am simulate rod-climming and die swell, but this work are just beginning, few tests for the methodology was done untill now!!
I advert you when the solver is released.
Best,
Jovani
Old   May 14, 2009, 18:27
Default viscoplastic constitutive model
  #16
xianghong wu
wendywu is on a distinguished road
Jovani,
I am planing to use OpenFOAM to simulate aluminum extrusion which is viscoplastic constitutive model. Will you give the viscoplastic constitutive model in the future? I think maybe for you it is a very easy work to do. But I just don't know how to do it and where I can get started to do it by myself. Could you please give me some advice?
Attatchment is the constitutive model. Thank you.
Wendy.
wendywu is offline   Reply With Quote
Old   May 14, 2009, 23:58
Kerstin Heinen
Hi Wendy,
What do you mean mathematically with D^d in the .doc?
D is a tensor and what is meant with the power of d???
At the moment I don't see any viscoelastic part in your equation. Viscoelastic properties are related to the left hand side (time derivative) of a constitutive equation. You should have a look on the theory of linear viscoelasticity, where material behaviour and equations are explained with spring's and dash-pots...(keyword: Maxwell fluids... ) you only have an explicit equation for stress tensor as a function of deformation gradient tensor with non constant viscosity...
but please explain the D^d further, bacause your material law looks interesting...
Kerstin
Old   May 15, 2009, 13:47
xianghong wu
Hi, thank you.
It is a viscoplastic model , not viscoelastic.
D is rate of deformation tensor, the superscript d represents deviator.
the equation for D is as attathment.
Thank you very much.
Wendy
Old   May 15, 2009, 14:41
xianghong wu
Hi, I have another constitutive model , maybe it is easier to realize. please see the attathment.
Thank you .
Have a nice day.
Wendy
Old   May 16, 2009, 02:14
Hrvoje Jasak
No pressure... but Jovani has got his examination on Monday - just registering support in public
Hrv
Hrvoje Jasak
VOF simulation of a viscoelastic fluid sinah OpenFOAM Running, Solving & CFD 11 December 25, 2017 03:00
FREE SURFACE VISCOELASTIC FLOWS Valdemir G. Ferreira Main CFD Forum 6 December 18, 2009 06:14
Viscoelastic flow modeling in OpenFOAM vulda OpenFOAM Running, Solving & CFD 1 March 17, 2008 07:32
Polyflow & OpenFoam on Viscoelastic flow modeling Sumeshen Main CFD Forum 0 March 14, 2008 08:29
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 05:09
