February 27, 2009, 11:37 |
I think at the moment i am usi
#61 |
Lukas Fischer
Rep Power: 17 |
I think at the moment i am using what you call constant velocity, i specify the boundary condition of U at the inlet via timeVaryingUniformFixedValue and a time series file in OF-1.5.
inlet { type timeVaryingUniformFixedValue; fileName "time-series"; outOfBounds warn; value uniform (0 0 0); } and a file "time-series" of this form: ( (0 (0 0 0)) (0.05 (0.0499947918294 0 0)) (0.1 (0.0999583385414 0 0)) (0.15 (0.149859414545 0 0)) (0.2 (0.199666833294 0 0)) . . . ) |
June 25, 2009, 08:46 |
#62 |
matteo lombardi
Rep Power: 17 |
i got one question and one answer: answer: as inlet BC for wave generation you can use this great library : http://openfoamwiki.net/index.php/Contrib_groovyBC (there is even a wavetank example) question: what about the non reflective BC?has anyone developed a version of wavetrasmissive BC for the interfoam solver?(the one implementd os for compressible gas if i am correct..) if not, Niels and kevin, is your sponge BC available? I presume it would work perfectly as well... Thank you very much, ciao matteo |
June 25, 2009, 10:47 |
#63 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Matteo
Unfortunately there are still some issues and verification on my present implementation which needs to be carried out, thus my implementation is not mature for release. As soon as it is, I will submit through the OF-extend's svn. However non-reflective inlet and outlet boundaries are implemented and easily to extend to different wave theories. I will make sure to post a note. Best regards, Niels |
August 19, 2009, 04:15 |
#64 |
Gonzalo Tampier
Rep Power: 17 |
Hi all,
I have a actually a new question/thread but I think it passes perfectly to the title of this thread: I think many of you (including me) has been successful modeling (harmonic) water waves with the groovyBC quite well: does anyone have experience validating these waves with analytical results? After dealing with grid quality problems and wave reflection at the outflow I have managed to get quite good results for a 2nd order Stokes wave. My problem appears when I do the same for a wave + inlet velocity (moving observer -> encounter freq.). The wave amplitude and the wave shape doesn't match anymore with analytical results, and the wave profile looks quite ugly. I've been trying different settings, but without success until now. Does anyone have had similar experiences? btw, the wave reflection problem mentioned in previous tasks can be eliminated very easily "numerically", by making an extreme coarse grid at the outflow region. It's not an elegant solution, but it works for me ;-) Best Regards, Gonzalo |
October 30, 2009, 10:43 |
3D Tank sloshing result comparison with theoritical results using interDyMfoam
#65 |
lostin
Rep Power: 16 |
Hi all,
I have simulated tank3dsloshing using interDymfoam. For having a clear picture of comparison of theoretical and simulation results I am using natural mode frequency of tank. As far as surface mode are concern I am getting very perfect match with theoretical result for lower frequencies. But in case of tank3d sloshing there should be mode in both the direction ( direction along which table is vibrating(width) and along length. In the simulations results along the width are perfectly ok but there is no mode shape along the length of the tank ( I have done the experiment on vibration shake table and the modes were there. ) Can anyone tell how I can correct this? Another thing is the amplitude are not as high as they should in resonance case. For 3D tank the mode frequency is calculated by mode frequency f is calculated as.. omega = 2*pi*f omega = sqrt (gktanh(kh)) k = pi*sqrt((2m/W)^2+(2n/L)^2) m and n are the natural mode along the width and length. h is water level height in tank . in my case it is 6cm. problem specifications : Rectangular tank 35X50X40 cm translation vibration for table given along 50 cm length freq. is applied corresponding 3 mode along 50cm and 3rd mode along 35 cm .. m =3 and n=3 in above equation. I will send the files and simulation video if someone want to see. Here i am not able to share those due to size limit of forum. Thanks |
March 3, 2010, 04:52 |
interFoam crash in a 2D groovy wave tank
#66 |
afshar
Rep Power: 16 |
Hello everyone
I have just used the groovyBC to simulate a 2D wave tank on OF 1.6.x. I acted upon the instructions in "http://openfoamwiki.net/index.php/Contrib_groovyBC" and I managed to compile, mesh and set the fields. Unfortunately interFoam crashes some time after the run and reports following lines on the terminal. Could anyone please kindly give me his/her opinion and recommendations on this? Regards Amini Afshar GAMG: Solving for p, Initial residual = 0.00018406464, Final residual = 2.4874203e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 3.8566011e-06, Final residual = 1.1349343e-07, No Iterations 3 GAMGPCG: Solving for p, Initial residual = 3.9084748e-07, Final residual = 4.6119893e-09, No Iterations 7 time step continuity errors : sum local = 4.0037774e-08, global = -4.0260771e-09, cumulative = 4.0826213e-07 ExecutionTime = 7.7 s ClockTime = 7 s Courant Number mean: 0.015971948 max: 0.47595885 deltaT = 0.01 Time = 0.69 MULES: Solving for alpha1 Liquid phase volume fraction = 0.47207799 Min(alpha1) = -0.028818711 Max(alpha1) = 1.0000086 MULES: Solving for alpha1 Liquid phase volume fraction = 0.47189442 Min(alpha1) = -0.043882922 Max(alpha1) = 1.0000086 MULES: Solving for alpha1 Liquid phase volume fraction = 0.47171085 Min(alpha1) = -0.058956843 Max(alpha1) = 1.0000087 GAMG: Solving for p, Initial residual = 0.00018071337, Final residual = 7.8103561e-06, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libfiniteVolume.so" #8 main in "/home/mostafa/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/interFoam" #9 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #10 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122 Floating point exception |
March 3, 2010, 05:13 |
#67 |
Gonzalo Tampier
Rep Power: 17 |
Hi Amini,
I would recommend you to take a look of your latest saved time step with paraFoam and check if everything looks "physically correct". If yes, post your fvSchemes and fvSolution here and I'll take a look of it. Specially your min alpha1 looks a little strange: it should be 0 or a value near to it within numerical errors, your value seems to me a little strange. Regards, Gonzalo |
March 3, 2010, 05:37 |
#68 |
afshar
Rep Power: 16 |
Thanks a lot Gonzalo Tampier
I looked at paraFoam and it seems that everything up to the crash moment is normal. At least a wave like motion for a while can be distinguished in it. I brought some change to the setting before the run since there were some complaints regarding the syntax in OF 1.6. Like gamma to alpha and dynamic pressure pd to p. Also I changed the original syntax for matrix preconditioner in fvsolution to have interFoam running. Here come fvsolution and fvscheme files: Regards Mostafa Amini Afshar /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { pcorr PCG { preconditioner { preconditioner GAMG; tolerance 1e-3; relTol 0; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nBottomSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; tolerance 1e-4; relTol 0; maxIter 100; }; p GAMG { tolerance 1e-8; relTol 0.05; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; pFinal PCG { preconditioner { preconditioner GAMG; tolerance 1e-8; relTol 0; nVcycles 2; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; tolerance 1e-8; relTol 0; maxIter 20; }; U smoothSolver { smoother GaussSeidel; tolerance 1e-6; relTol 0; nSweeps 1; }; k PBiCG { preconditioner DILU; tolerance 1e-08; relTol 0; }; B PBiCG { preconditioner DILU; tolerance 1e-08; relTol 0; }; nuTilda PBiCG { preconditioner DILU; tolerance 1e-08; relTol 0; }; } PISO { momentumPredictor no; nCorrectors 3; nNonOrthogonalCorrectors 0; nAlphaCorr 1; nAlphaSubCycles 3; cAlpha 1; pRefCell 0; pRefValue 0; pRefProbe { fields (p); probeLocations ((0.51 0.51 0.51)); }; } // ************************************************** *********************** // and /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(U) Gauss linear; grad(alpha) Gauss linear; } divSchemes { div(rho*phi,U) Gauss limitedLinearV 0; div(phi,alpha) Gauss vanLeer01; div(phirb,alpha) Gauss interfaceCompression; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; pcorr; alpha1; } // ************************************************** *********************** // |
March 8, 2010, 00:44 |
#69 |
Rep Power: 16 |
Hi Amini,
I met similar problem as yours, I changed the settings in fvSolution which is from setting in sloshing tutorial case, it run to 9 seconds, and then it crashed. I am just wondering how can I set the parameters in the file fvSolution. I will be very appreciate anyone who can give me some suggestions. Thanks. Best regards, Elliot |
March 8, 2010, 01:02 |
#70 |
afshar
Rep Power: 16 |
Hi Elliot
I managed to fix the problem by lowering max Courant Number and max deltaT" in controlDict. Regards Amini Afshar |
March 8, 2010, 15:25 |
#71 |
Rep Power: 16 |
Hi Amini,
Did you fix the problem by lowering the max Courant NO. and max deltaT? I tried to do this, it runs to a longer time, but it crashed at last. Thanks. Best regards, Elliot |
March 9, 2010, 14:19 |
#72 |
afshar
Rep Power: 16 |
Hello
Yes I did and It toke longer time. Just to inform you that I was running a 2D wave tank using GroovyBC and its computational requirements may be different than sloshing case. Cheers Amini Afshar |
March 9, 2010, 15:05 |
#73 |
Rep Power: 16 |
Thanks for your message. I will try it again. Best regards, Elliot |
July 12, 2010, 13:01 |
wave tank OpenFoam 1.7.0
#74 |
victor
Rep Power: 15 |
Hello
I made a test for the wavetank using groovyBC with OpenFoam 1.7.0. I downloaded groovuWaveTank.tgz I found a first problem and fix it with bison Then I got an error message: ------------------------------------------------------------- --> FOAM FATAL IO ERROR: cannot open file file: /home/vrosaless/OpenFOAM/vrosaless-1.7.0/run/multiphase/interFoam/ras/groovyWaveTank/0/p_rgh at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 61. FOAM exiting ------------------------------------------------------------ From another post in CDF online I try setFields but it doesn't work. Further in that disscution they emntion something about "reconstruct" but I don't get the idea how to fix the problem in the wave Tank case. Thanks for any help Victor |
July 12, 2010, 13:26 |
#75 |
Rep Power: 16 |
From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 61. Did you have the file "p_rgh" in the directory "0"? |
July 12, 2010, 13:29 |
#76 |
victor
Rep Power: 15 |
no I don't have p_rgh
in the 0 foulder I got: pd gamma.org gamma.gz U.gz Victor |
July 12, 2010, 13:34 |
#77 |
Rep Power: 16 |
I think you need to modify the pd to p_rgh, gamma to alpha1, and then try and see
July 12, 2010, 15:06 |
#78 |
victor
Rep Power: 15 |
So far...
In fact I was running an old version of wave Tank. The most recently for OF 1.6 is updated with the variables needed. From that there is an error concerning a variable maxAlphaCo: I updated controlDict MaxAlphaCo 0.9; Then I update fvschemes fluxRequired { default no; p_rgh; pcorr; alpha; } It's now running... Victor |
July 26, 2010, 07:17 |
#79 |
Emanuele
Rep Power: 17 |
Hi, i downloaded and ran groovyBc wave tank case in 1.7.0 but i have a problem: the level of water goes up along z direction and it stops his level near to atmosphere patch. Is it the correct behaviour ??
I attach the case ready to run http://dl.dropbox.com/u/3617688/groo...Tank170.tar.gz |
July 26, 2010, 09:21 |
#80 |
yannH
Rep Power: 16 |
hi nuovocha,
I look quickly at your files, why did you put zeroGradient for boundary condition of your pressure p ? I think you should write ''type buoyantPressure;'' like it was in previous versions. best regards, Yann |
wavetank |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 02:32 |
Numerical wave tank | michaelp | OpenFOAM Installation | 1 | December 17, 2008 08:27 |
Numerical wave tank | Bridget | FLUENT | 0 | March 27, 2006 16:09 |
Sea Waves/Wave tank | Phil | FLUENT | 3 | October 9, 2003 06:55 |
Virtual wave tank | Murali.K | Main CFD Forum | 1 | March 17, 1999 02:18 |
