Ignition method
Like Tree2Likes
  • 1 Post By viji
  • 1 Post By lfgmarc
Old   April 28, 2005, 03:43
Default Hello, What is the method i
Chalothon Thumthae
thumthae is on a distinguished road
What is the method in ignition process of solver XiFoam and engineFoam?
when I run a model with engineFoam and compare result with experiment, pressure from simulation result is rise before the experiment.
Does it mean ignition method in openFoam does not include ignition delay?
and What is "strength" parameter in combustionProperties ?
please give me for suggestion.
Torn
thumthae is offline   Reply With Quote
Old   April 28, 2005, 04:03
Default The best way to understand the
henry is on a distinguished road
The best way to understand the ignition modelling used in XiFoam and engineFoam is to study the source code and write down the equations being used. You will find everything you need in
OpenFOAM-1.1/applications/solvers/combustion/XiFoam
OpenFOAM-1.1/applications/solvers/combustion/engineFoam
OpenFOAM-1.1/src/engine/ignition
OpenFOAM-1.1/src/engine/include/StCorr.H
henry is offline   Reply With Quote
Old   September 30, 2008, 05:48
Default Dear All Currently I am wor
Vijayaratnam Piradeepan
piradeepan is on a distinguished road
Dear All
Currently I am working in XiFOAM.
Please let me know, what the unit of ignition strength in combustion properties is.
Thank you
Vijay
piradeepan is offline   Reply With Quote
Old   February 12, 2009, 03:39
Default hi i am from india i am new to
pavan
viji is on a distinguished road
hi i am from india i am new to openfoam i am solving methane combustion problem, i am facing difficulty while assigning fields and solving please can u help me... or for reference can u send one combustion solved problem..
apsingh_21 likes this.
viji is offline   Reply With Quote
Old   June 4, 2011, 03:04
Unhappy Ignition points?
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Hi, maybe one of you can help me, I too want to know the units of the ignition strenght and how I can define more ignition points in the combustion properties ?
best regards
FG
Felipe G
lfgmarc is offline   Reply With Quote
Old   July 29, 2011, 03:47
Question ignition properties
M. Timaji
timaji is on a distinguished road
Send a message via Skype™ to timaji
Hi Foamers,
I have read ignite.H and found that bEqn updated to new value:
" bEqn = bEqn + Strength *cellVolume * rhou / duration " for ignite cells.
These anybodys know the perspective on physics of this formula?
Would you please help me on ignition properties e.g. strength, diameter and timing for carbon rod igniter.
timaji is offline   Reply With Quote
Old   June 5, 2013, 13:56
Camille
camille131 is on a distinguished road
Does anyone know how can I know the quantity of energy involved in the ignition in function of the parameters (strength, duration, ...) ?
I m also looking for an explaination of the meaning of strength
assuming b is a dimensionless number, I thought I could find the unity of strength from the next equation but Im not sure...
bEqn = beqn + ((strength * cellVolume * rhou) / duration ) / (b[ignSite] + 0.001)
cellVolume [ m³]
rhou [kg/m³]
duration [s]
b[ignSite] and bEqn [-]
strength [?]
Then : [-] = [?] *[m³]*[kg/m³] / [s] --> [?] = [s/kg]
but it means nothing for me physically in this context...
for sur I am wrong but where? maybe rhou is not what I think?
Thank you for your help,
Cam
camille131 is offline   Reply With Quote
Ignition Mgtripple CFX 7 January 19, 2020 14:36
Ignition ylime FLUENT 1 March 9, 2010 20:01
Ignition jonathan CFX 0 March 11, 2008 12:53
Spark Ignition Nico Gross FLUENT 0 November 8, 2007 13:07
H2/O2 ignition ??? abel FLUENT 2 June 8, 2006 05:03
