Epsilon and mixing length value for airfoil simulation
Old   January 29, 2009, 06:50
Default Hi all, I'm trying to simulat
Gianluca VZ
gian_ing is on a distinguished road
Hi all,
I'm trying to simulate a turbulent flow around an airfoil. I have some difficulties in evaluating the correct value for epsilon.
In particular I don't know which value of the mixing length I should use.
The domain is 3 meters long and 2 high.
The airfoil is located at 1 meter from the inlet and in the middle of the height, the chord length is 0.1 m, the speed is 100 m/s, Re=1e6.
Thank you in advance for your suggestions.
Bye
Gianluca
gian_ing is offline   Reply With Quote
Old   January 29, 2009, 08:33
Default Hi, this is what I obtained so
Gianluca VZ
Hi, this is what I obtained so far.
I attach the directory of the case and a screenshot.
Thanks again.
airfoil_simulation.zip
Gianluca
Old   January 29, 2009, 11:32
Default hi, your U value seams to b
Wolfgang Heydlauff
wolle1982 will become famous soon enough
hi,
your U value seams to be 10m/s instead of 100. you also will have to raise the size of your mesh to 40-100 times the chordlength.
wolle1982 is offline   Reply With Quote
Old   January 29, 2009, 14:17
Default Actually, Gianluca and I tried
antonio segalini
antonio_ing is on a distinguished road
Actually, Gianluca and I tried to do a different simulation with the k and epsilon of a simulation of prof.Jasak on a naca 0012. with the same chord length and the same distance. but you see the result (it is embarassing :-) )
antonio_ing is offline   Reply With Quote
Old   January 30, 2009, 16:32
Default Hello Antonio and Gianluca,
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
Try to keep y+ approx 1 to 5 and use sst k-w model. You shall check the best practise guidelines in ERCOFTAC for such flow.
Naca profile example is there in it... May be it helps you.
good luck
maruthamuthu_venkatraman is offline   Reply With Quote
Old   January 31, 2009, 13:15
Default Mmmm, the k-Omega SST coded
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Mmmm,
the k-Omega SST coded in OF is based on a wall functions approach, so it should be necessary to use an y+ of about 30...
egards, Ivan
ivan_cozza is offline   Reply With Quote
Old   February 1, 2009, 03:55
Default thanks Ivan and Maruthamuthu.
antonio segalini
thanks Ivan and Maruthamuthu. We find out our bug :-). In the boundary file we did not specify that the profile surface was of wall type. There are other types in OpenFOAM (inlet, outlet, etc...)
Is it so important to specify the other types (apart wall of course)?
mixing length lili Siemens 1 February 5, 2007 19:22
mixing length model mukkarumhussain Main CFD Forum 2 August 6, 2002 00:02
mixing length mukkarum Main CFD Forum 4 July 25, 2002 05:16
mixing length rafat FLUENT 0 June 7, 2002 04:51
Mixing length Sabatini Siemens 3 December 31, 2000 05:08
