Nearwall treatment for the kOmegaSST turbulence model |
January 20, 2009, 12:58 |
I am currently doing vehicle a
John.B
I am currently doing vehicle aerodynamics simulation with OpenFoam v1.5 and using simpleFoam with the incompressible implemented kOmegaSST turbulence model. My main concern is when this model is valid in terms of y+. Since it uses wall functions I guess the y+ should be in the log-law region (30<y+<300) and hence it would be improper to have a finer mesh with lower y+ (in my case y+ ~7) together with this model?
Would it be an idea to try a Low-Re turbulence model like Launder-Sharma or QZeta, or would that require a further refined mesh (y+~1)? Thanks in advance! |
January 21, 2009, 07:02 |
If you want to use low-Re mode
Kati Laakkonen
If you want to use low-Re model, you should see that all walls have y+~1 (4-5 should still be okay in some places, but 7 is quite a lot). If I were you doing vehicle aerodynamics, I would use SpalartAllmaras. It is a hybrid model, so if you select nutWallFunction as boundary condition for nut on walls (mut/mutWallFunction if compressible) you don't need to worry so much about y+, because the model uses different treatment depending on the y+ value.
The low-Re models can be tricky, I've heard. There are many of them i.e. none is very general, and epsilon equation is very sensitive to grid on the wall. One more point with standard wall functions: the theory is valid only for flat plates (straight ducts maybe too - I don't remember), so that all pressure gradients and especially separation or attachment are not well predicted. So even if your y+ is in the correct limits, you may not get good results with wall functions. Regards, Kati |
January 21, 2009, 12:22 |
Hi John,
I'm facing the same
Hi John,
I'm facing the same questions, I'm trying to solve a Re 1.3e5 flat plate with a tickness equal to 3% of the chord. As I'm interested in the k and eps fields, I would like to resolve well the boundary layer with something like a low Re model, and I know that k-Omega SST as some low Re version, but I know that now in OpenFOAM there's only the wall function version... Has anyone the low Re version for SST? |
January 22, 2009, 02:52 |
Hi Kati and Ivan,
Thanks for
John.B
Hi Kati and Ivan,
Thanks for the advice, I will try using SpalartAllmaras (and post how it goes here) and I guess you use nutWallFunction with a zero (or say 1-e10) value of nut at the wall boundaries. What would be very interesting for the KOmegaSST model (as well as other turbulence model using wall function approach) is to implement an enhanced wall treatment. In such way I guess that a coarse mesh region will correspond to a wall function approach (zeroGradient) while a fine mesh region will use an appropriate Low-Re boundary condition (fixedValue). Does anyone know if there are plans on releasing such option? It seams like these three posts is handling modification to the existing kOmegaSST model, very interesting: http://www.cfd-online.com/OpenFOAM_D...tml?1231869877 http://www.cfd-online.com/OpenFOAM_D...tml?1186414688 http://www.cfd-online.com/OpenFOAM_D...tml?1220457716 Regards, John |
Turbulence treatment in porous media | sebastiank | OpenFOAM Running, Solving & CFD | 2 | May 8, 2017 04:29 |
Wall Treatment of User defined Turbulence Model | Yang Chung | FLUENT | 0 | August 23, 2008 11:31 |
How can run MRFSimpleFoam with KOmegaSST turbulence model | waynezw0618 | OpenFOAM Running, Solving & CFD | 0 | April 21, 2008 04:40 |
Question on new implemented komegaSST model in OF 14 | peterh | OpenFOAM Running, Solving & CFD | 7 | February 7, 2008 02:09 |
compressible modification of nearwall turbulence | Quain Tchew | Main CFD Forum | 0 | March 4, 2002 01:29 |
