Specifying nonuniform initial condition
Like Tree6Likes
Old   March 25, 2005, 11:05
Default Hi, I have a 2D domain consis
msyaml
I have a 2D domain consisting of four blocks. I want to specify the initial condition for a field variable as T=1 in block 0 and as T=0 in the other three blocks. Is there a way to specify the initial condition block-by-block? i.e., in file T in folder 0 use the keyword non-uniform and specify a list of blocks and the corresponding T values. I am a novice user and was not able find an example for this in the user's or programmer's guide or in tutorial cases (e.g., damBreak example is similar but seems to use an initialization program). Thanks.
Syam
Old   March 25, 2005, 11:34
Default The concept of blocks only exi
Mattijs Janssens
The concept of blocks only exists in blockMesh. (assuming that you are using blockMesh) After mesh generation (with whichever mesh generator you use) OpenFOAM has no concept of blocks. The whole mesh is one unstructured set of cells of arbitrary shape.
Since there is no information kept on what cells originate from what block you'll have to select them yourself. The damBreak application comes closest to your needs I think.
Mattijs
Old   March 25, 2005, 12:04
Default What if you build another case
diablo80@web.de
sampaio is on a distinguished road
What if you build another case, with only one block, coinciding with the one you want T=1. Than, if you use mapFields from there to your actual case....
Would that work for you?
I know, it is a little dirty solution...
Luiz
sampaio is offline   Reply With Quote
Old   March 25, 2005, 15:16
Default Luiz, Thanks for that clever
msyaml
Luiz,
Thanks for that clever solution! Although an additional case was needed, your solution reduced the complexity of the original case (fewer blocks) and eliminated the need for an initialization program.
Syam
Old   November 15, 2005, 14:06
Default I'm trying to set a turbulent
Maka Mohu
maka is on a distinguished road
I'm trying to set a turbulent nonuniform initial condition for a channel flow case. The field is available in a file with the format (column-wise):
x y z u v w p
1) I found that SetField utility that is used in the dam break case (1.2) is designed to do similar job but it uses dictionary as its input. Can any body explain how to use or modify the utility to use a data file as input.
2) I also thought of using mapField utility after trying to make a new case and cast my data into the OpenFOAM format but I faced the following problem:
the file constant/polyMesh/"points" describes vertices while what is available at my case is the node values that correspond to the values of 0/U and 0/p. I would be grateful if some body can give some help about how to solve this problem.
3) one final question about constant/polyMesh/cells: does the file format of openFOAM enforces any rules regarding the order of cells in the file or it is fully unstructured and I can order the cells as I like as long as it is consistent with 0/U, and 0/p format.
Thanks.
best regards,
Maka
maka is offline   Reply With Quote
Old   November 15, 2005, 14:40
Default I noticed a talk about cellSet
Maka Mohu
I noticed a talk about cellSet in:
http://www.cfd-online.com/OpenFOAM_D...tml?1131637441
http://www.cfd-online.com/OpenFOAM_D...es/1/1240.html
Can any one explain or give example of how to use cellSet to solve this problem or even what is cellSet? sorry I'm a beginner. Thanks.
Regards,
Maka
Old   November 16, 2005, 04:28
Default Look at e.g. interFoam/system/
Mattijs Janssens
Look at e.g. interFoam/system/setFieldsDict.
It uses the 'boxToCell' source. Instead you can use say the 'cellToCell' source which allows you to use a cellSet. (b.t.w. these sources are exactly the same one cellSet uses)
Mistype it and run setFields to see all the possible sources.
Old   November 16, 2005, 10:36
Default in boxToCell, we have ďťżdef
VVqf
vvqf is on a distinguished road
ďťżdefaultFieldValues
volScalarFieldValue alpha 1
regions
boxToCell
box (0.4 0 0) (1 1 0.1);
fieldValues
volScalarFieldValue alpha 0.1
What about cellToCell, how to write this?
I looked into the source codes cellToCell.H/C, but didn't find answer.
vvqf is offline   Reply With Quote
Old   November 17, 2005, 05:05
Default to e.g. read cellSet c0 replac
Mattijs Janssens
to e.g. read cellSet c0 replace the
boxToCell
box (..)(..)
fieldValues ...
with:
cellToCell
set "c0";
fieldValues ...
(or maybe lose the quotes around c0)
Also look at the sample cellSetDict in the cellSet utility.
Old   January 4, 2006, 06:39
Default Hi Mattijis How to read in
Nico Petry
nico is on a distinguished road
Hi Mattijis
How to read in a file containig a list of cells, for example /constant/polyMesh/sets/fluid.1 ?
The file looks like:
FoamFile
version 2.0;
format ascii;
root "OpenFOAM/nico-1.2/run/tutorials/simpleFoam";
case "test01";
instance ""constant"";
local "polyMesh/sets";
class cellSet;
object fluid.4;
240
50
51
52
53
279
280
Thanks and a happy new year
nico is offline   Reply With Quote
Old   January 13, 2006, 04:04
Default As an example for reading a ce
  #11
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
As an example for reading a cellSet and manipulating data in these cells you can use this:
http://openfoamwiki.net/index.php/Contrib_setfiel dbycellset
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   March 20, 2006, 11:29
Default Hello, I would like to spec
  #12
Mélanie Piellard
melanie is on a distinguished road
I would like to specify non uniform initial conditions for my case, with respect to the coordinates of the nodes.
Exemple: the velocity field is defined such as
r = x^2 + y^2
U[x] = y * a/ r^2
U[y] = -x * b/ r^2
How would you write it ? Firstly, I don't know how to access to the nodes coordinates which is blocking me...
Thanks.
melanie is offline   Reply With Quote
Old   March 21, 2006, 04:09
Default Look at the setGammaDambreak a
  #13
Mattijs Janssens
Look at the setGammaDambreak app from OpenFOAM1.1. Or look on this site for setGammaField. It should contain how to access coordinates.
Old   March 21, 2006, 04:54
Default Mattijs, I looked at the DamB
  #14
Mélanie Piellard
Mattijs,
I looked at the DamBreak case, but the velocity field is set thanks to a bounding box, so this is a different case.
Here I report what I have already written, with the error message at compilation:
#include "fvCFD.H"
#include "physicalConstants.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
scalar pi = physicalConstant::pi;
scalar r_0 = 0.0036;
scalar r_c = r_0*2.0/9.0;
scalar gamma = 4.0 * pi * r_c * 340.0 / 2.0;
forAll(mesh.C(), celli)
scalar x = mesh.C()[celli].x;
scalar y = mesh.C()[celli].y;
scalar r_1 = ::pow((x+r_0)*(x+r_0) + y*y ,0.5);
scalar r_2 = ::pow((x-r_0)*(x-r_0) + y*y ,0.5);
scalar V_theta1 = - gamma * r_1/(2.*pi*(r_c*r_c + r_1*r_1));
scalar V_theta2 = - gamma * r_2/(2.*pi*(r_c*r_c + r_2*r_2));
scalar Ux = -y * (V_theta1/r_1 + V_theta2/r_2);
scalar Uy = (x-r_0) * V_theta1/r_1 + (x+r_0) * V_theta2/r_2;
scalar Uz = 0.0;
U[celli] = (Ux Uy Uz);
U.write();
Info << "\n end\n";
return(0);
tzntgq@cfdlem04:~/OpenFOAM/OpenFOAM-1.2.1/applications/utilities/preProcessing/corotVortex> wmake
Making dependency list for source file corotVortex.C
SOURCE_DIR=.
SOURCE=corotVortex.C ; g++ -m64 -DlinuxAMD64 -Wall -W -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -Wno-deprecated -I/home/tzntgq/OpenFOAM/OpenFOAM-1.2.1/src/cfdTools/compressible -I/home/tzntgq/OpenFOAM/OpenFOAM-1.2.1/src/cfdTools/general/lnInclude -I/home/tzntgq/OpenFOAM/OpenFOAM-1.2.1/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -c $SOURCE -o Make/linuxAMD64Gcc4Opt/corotVortex.o
corotVortex.C: In function 'int main(int, char**)':
corotVortex.C:57: error: cannot resolve overloaded function 'x' based on conversion to type 'Foam::scalar'
corotVortex.C:58: error: cannot resolve overloaded function 'y' based on conversion to type 'Foam::scalar'
corotVortex.C:70: error: expected `)' before 'Uy'
corotVortex.C:70: error: no match for 'operator=' in 'U.Foam::GeometricField<foam::vector,>::<anonymous >.Foam::Field<foam::vector>::< anonymous>.Foam::List<foam::vector<foam::scalar> >::<anonymous>.Foam::UList<t>::operator[] [with T = Foam::vector](celli) = Ux'
/home/tzntgq/OpenFOAM/OpenFOAM-1.2.1/src/OpenFOAM/lnInclude/Vector.H:62: note: candidates are: Foam::Vector<foam::scalar>& Foam::Vector<foam::scalar>::operator=(const Foam::Vector<foam::scalar>&)
corotVortex.C:67: warning: unused variable 'Uy'
corotVortex.C:68: warning: unused variable 'Uz'
make: *** [Make/linuxAMD64Gcc4Opt/corotVortex.o] Error 1
At compilation, x and y are not recognized and the vector field U is not understood...
Could anyone give me a hint please ?
achinta likes this.
Old   March 21, 2006, 07:35
Default maybe try forAll(mesh.cells(
  #15
Pierre Le Fur
pierre is on a distinguished road
maybe try
forAll(mesh.cells(), cellsI)
scalar x = mesh.C()[cellI].component(0)
rather than forAll(mesh.C(), celli)...
Pierre
pierre is offline   Reply With Quote
Old   March 21, 2006, 08:26
Default Thank you Pierre, it worked fo
  #16
Mélanie Piellard
Thank you Pierre, it worked for x and y with actually
forAll(mesh.cells(),cellI)
scalar x = mesh.C()[cellI].component(0).
Now I still have a problem with the velocity; I have defined Ux, Uy and Uz, and the line
U[cellI] = (Ux, Uy, Uz);
gives me the error message
corotVortex.C:71: warning: left-hand operand of comma has no effect
corotVortex.C:71: warning: right-hand operand of comma has no effect
corotVortex.C:71: error: no match for 'operator=' in 'U.Foam::GeometricField<foam::vector,>::<anonymous >.Foam::Field<foam::vector>::< anonymous>.Foam::List<foam::vector<foam::scalar> >::<anonymous>.Foam::UList<t>::operator[] [with T = Foam::vector](cellI) = (((void)Ux, (void)Uy), Uz)'
Old   March 21, 2006, 08:55
Default try U = vector(Ux, Uy, Uz);
  #17
Pierre Le Fur
try
U[cellI] = vector(Ux, Uy, Uz);
Pierre
Old   March 21, 2006, 09:54
Default thank you Pierre, now everythi
  #18
Mélanie Piellard
thank you Pierre, now everything is working well !
mélanie
Old   March 26, 2006, 17:21
Default Inspired by this thread (and b
  #19
Assistant Moderator
Bernhard Gschaider
Inspired by this thread (and because I wanted such a thing for myself for some time) I decided to visit two friends of the time of my diploma thesis (the compiler generators bison and flex) and write a utility that can set fields using complex expressions (from the command line or with a dictionary). A first version is available at
http://openfoamwiki.net/index.php/Contrib_funkySe tFields
For instance the velocity field Melanie specified on the 20th:
r = x^2 + y^2
U[x] = y * a/ r^2
U[y] = -x * b/ r^2
could be set with the utility with the call (assuming a and b to be 1 and 2):
funkySetFields . theCase -field U -expression 'vector(pos().y*1/pow(mag(pos()),4),-pos().x*2/pow(mag(pos()),4),0)' -time 0
Another example would be setting the initial condition for the damBreak-tutorial:
funkySetFields . damBreak -time 0 -field gamma -expression " pos().x <= 0.1461 && pos().y <= 0.292 ? 1 : 0"
or (if you don't want to overwrite the whole gamma field):
funkySetFields . damBreak -time 0 -field gamma -expression 1 -condition "pos().x <= 0.1461 && pos().y <= 0.292"
Old   March 28, 2006, 05:54
Default Hi, can someone please expl
  #20
Anja Stretz
anja is on a distinguished road
can someone please explain me, what the following line defines
Thanks
Anja
anja is offline   Reply With Quote
Specifying nonuniform boundary condition maka OpenFOAM Running, Solving & CFD 59 October 22, 2014 14:52
Nonuniform initial condition using cellSetDict rinao OpenFOAM Running, Solving & CFD 6 January 9, 2013 00:42
Initial Condition Tang Kuei FLUENT 0 May 17, 2006 19:54
Nonuniform gradient boundary condition ankgupta8um OpenFOAM Running, Solving & CFD 1 March 14, 2006 01:34
Nonuniform initial conditions nico OpenFOAM Pre-Processing 2 January 4, 2006 06:37
