IOobject
Like Tree1Likes
Old   September 16, 2005, 05:28
Default Hi Guys, If I created an arr
Radu Mustata
r2d2 is on a distinguished road
Hi Guys,
If I created an array of volScalarFields with this syntax:
PtrList<volscalarfield> fields(2);
for (int i =0; i<2; i++)
word fieldName = "field" + Foam::name(i);
Info<< "Reading field " << fieldName<< endl;
fields.hook(
volScalarField
IOobject
fieldName,
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
and then I solve some equation for these (two fields for now), at runtime
runTime.write();
won´t print out these field values? Am I doing something wrong?
Cheers,
Radu
mm.abdollahzadeh likes this.
r2d2 is offline   Reply With Quote
Old   September 16, 2005, 13:11
Default - Is 'fields' still in scope b
Mattijs Janssens
- Is 'fields' still in scope by the time you call runTime.write() ?
- Do the fields actually get modified? (as far as I can remember only done by some field operators, e.g. assignment, solve)
You can set the debug flag for
objectRegistry
to check if anything gets written
Old   February 9, 2006, 07:48
Default Try adding before everything y
Radu Mustata
Try adding before everything you wrote
volVectorField* UmeanPtr;
Radu
Old   February 9, 2006, 08:29
Default The code already contains such
Maka Mohu
maka is on a distinguished road
The code already contains such declaration. Sorry I just posted some parts of the code.
Regards,
Maka
maka is offline   Reply With Quote
Old   February 9, 2006, 14:28
Default outputTime() probably only get
Mattijs Janssens
outputTime() probably only gets set if you use the
runTime++
method of incrementing time. This is the way all simulation codes work.
Looping over all times like the postprocessing tools do will not (and should not) take notice of the 'writeInterval' setting in the controlDict. So outputTime never gets set.
Look at one of the simple postprocessing tools (e.g. magU) on how to forcibly write a field.
Old   February 10, 2006, 10:05
Default Thanks Mattijs for your help.
Maka Mohu
best regards,
Maka
Old   February 14, 2006, 05:56
Default in the following part of the c
Maka Mohu
in the following part of the code, Umean.write() only works if it is writen in POSTITION 1 but not 2. The later is the required. It seems that runTime.setTime has some effect.
int main(int argc, char *argv[])
# include ...
# include "createTimeAverages.H"
// For each time step read all fields
forAll(runTime.times(), i)
Umean.write(); // POSITION 1
runTime.setTime(runTime.times()[i], i);
Umean.write(); // POSITION 2
Info<< "end" << endl;
return 0;
Umean is defined as :
const fileName& local = runTime.timeName();
volVector Field* UmeanPtr = new volVectorField
IOobject
"Umean",
local,
mesh,
wo
mesh
volVectorField& Umean = *UmeanPtr;
I would apreciate any help. Thanks.
best Regards,
Maka
Old   February 14, 2006, 09:50
Default Umean.write() does not work in
Maka Mohu
Umean.write() does not work in POSITION 2 but works outside the loop before main returns. I can live with that. Now, I tried to control the place where Umean.write() writes files by changing:
const fileName& local = "statistics";
but it does not write in statistcs folder, which is a folder that I made to collect all statistics. This makes backup easier since instanous data (big size) and statistics (small size) are separated.
any suggestions?
Thanks,
Maka
Old   February 20, 2006, 08:14
Default forcing a read operation Wo
Maka Mohu
Would you please, point to the documentation of write() member function for a volVectorField? is there a read().
I looked into Doxygen docs:
I found:
GeometricField<vector,> volVectorField
Then I looked into all the involved classes, I could not find a write() memeber functions.
Thanks,
Maka
Old   February 21, 2006, 07:07
Default runTime.end() does not work if
Maka Mohu
runTime.end() does not work if you are postprocessing an existing data even if you use runTime.setTime,
This is part of the code:
//mesh.readUpdate();
U = volVectorField
IOobject
"U",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::NO_WRITE
U
# include "calculateTimeAverages.H"
// Average fields over channel down to a line
# include "spaceAverageFields.H"
if (runTime.end())
# include "writeTimeAverages.H"
My question is does any one understand why member functions of Time class works only when the solver is running? What should we do to let them work when we are processing a data? Thanks.
Thanks,
Maka.
Old   February 21, 2006, 07:16
Default You could just read the end ti
  #11
Eugene de Villiers
eugene is on a distinguished road
You could just read the end time from controlDict and explicitly test for it.
In Time.C line 341
bool Foam::Time::end() const
return (value() > (endTime_ + 0.5*deltaT_));
So you see your current time has to be at least 0.5 * deltaT larger than endTime to return true.
eugene is offline   Reply With Quote
Old   March 4, 2008, 11:00
Default I expected the following code
  #12
Maka Mohu
I expected the following code to print: volScalarField T but it prints IOobject T; Is there a way to read the class name that is written in the header file of an IOobject other than headerClassName() (I refer to version 1.3). Thanks.
IOobject Xheader
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ
Info<< "Reading " << Xheader.headerClassName() << " " << varname << endl;
Old   March 4, 2008, 12:06
Default The header is not read automat
  #13
Maka Mohu
The header is not read automatically. The solution is to add the following before using header.headerClassName().
// read header
Xheader.headerOk();
Old   December 9, 2008, 08:02
Default Good morning, I'm writting
  #14
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Good morning,
I'm writting a basic code to produce the necessary files in order to use the timeVaryingMappedFixedValue patch. However, I'm not able to write my object in the specified path.
IOobject IOUpatch
"U",
runTime.constant()/"boundaryData"/"patchTest",
//runTime.constant(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE,
false
vectorIOField Upatch(IOUpatch, sizeMesh);
For some reason, when Upatch.write(); is called, the file is written in my initial time step (0). Not sure why - any ideas ?
Regards,
PO
podallaire is offline   Reply With Quote
Old   December 10, 2008, 05:08
Default Is there a directory called "c
  #15
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Is there a directory called "constant/boundaryData/patchTest" in your case directory?
Dragos
dmoroian is offline   Reply With Quote
Old   December 10, 2008, 07:27
Default yes I have it Thanks PO
  #16
yes I have it
Thanks
PO
Old   December 11, 2008, 01:33
Default Hm, then I suggest that right
  #17
dmoroian's Avatar
Dragos
Hm, then I suggest that right below the line IOUpatch.write() (I think there is a typo in your post Upatch.write() instead of IOUpatch.write()) insert a new one: system("touch your_case_dir/constant/boundaryData/patchTest/bubu").
See if the file "bubu" gets created!
Dragos
Old   July 31, 2009, 12:22
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I'm currently struggling on the same problem.
I don't know how to specify a particular path when writing a field.
Basically I want to do the same as podallaire in his thread from 9. December 2008.
Has anybody found a solution to this problem?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   July 31, 2009, 12:37
Unfortunately I did not solve the issue since groovyBC was the perfect
candidate for what I wanted to do.
Maybe this program can help you :
OpenFOAM-1.5.x/tutorials/interDyMFoam/sloshingTank3D6DoF/gen6DoF
Regards,
PO
Old   July 31, 2009, 12:48
sega's Avatar
Sebastian Gatzka
Thanks for your answer. Looks like this file shows me how to write a specific file. But thats what I have already managed to do.
Writing the file with this OFstream command leaves the header, which is essential to the timeVaryingMappedFixedValue boundary condition.
Doing this with headers by creating an IOobject I can't choose the right path.
Just frustrating!
A question on IOObject ivan_cozza OpenFOAM 0 September 16, 2008 03:24
Create GeometricField without IOobject nadine OpenFOAM Running, Solving & CFD 3 August 15, 2008 09:24
IOobject and IOfield in OpenFoam xiao OpenFOAM Running, Solving & CFD 0 April 2, 2008 21:56
Use of IOobject to Output irishdave OpenFOAM Pre-Processing 1 January 8, 2008 11:12
IOobject constructor problem iyer_arvind OpenFOAM Running, Solving & CFD 3 November 19, 2006 06:39
