SteadyState solver for compressible flow
Old   February 15, 2008, 08:38
Default Hi to all, I have a flow with
matteo_gautero
Hi to all,
I have a flow with Mach=0.3. I'm needing a steady state solver for compressible flow, but in the user guide there aren't any solver for steady state case. Can anyone help me?
Matteo.
Old   February 15, 2008, 17:09
Default check out rhoSimpleFoam. th
Shaun Darmody
shaun is on a distinguished road
this will be what you are looking for.
Regards
Shaun.D
shaun is offline   Reply With Quote
Old   February 18, 2008, 09:00
Default Thanks Shaun. I have a problem
matteo_gautero
Thanks Shaun. I have a problem. This solver is not present in FoamX and in the tutorials folder. I have to compile rhoSimpleFoam or I've done some errors in the installation procedure?
Regards,
Matteo.
Old   February 19, 2008, 03:24
Default You just have to set up the ca
Maximilian Graser
graser is on a distinguished road
You just have to set up the case by hand without FoamX.
graser is offline   Reply With Quote
Old   February 19, 2008, 03:37
Default Hi, I also want to know how
myting
I also want to know how I can set up the case by hand. Can somebody give me an example for this solver please.
Old   February 19, 2008, 03:56
Default look at these tutorials: rhoE
Maximilian Graser
rhoExplicitPorousSimpleFoam
rhoImplicitPorousSimpleFoam
they use rhoSimpleFoam solver
Old   February 19, 2008, 06:37
Default you could also simple search t
Shaun Darmody
you could also simple search the forum for "rhoSimpleFoam" and you will find some references to case setup.
I believe I can post the case setup tomorrow when at work.
Shaun.D
Old   February 19, 2008, 06:59
Default Hi, thanks, I think, I will
myting
thanks, I think, I will try to change the case "rhoImplicitPorousSimpleFoam" solver to "rhoSimpleFoam".
In the forum I found this information:
"I have tried to create a FoamX configuration for rhoSimpleFoam. Just untar it under $FOAM_SOLVERS/rhoSimpleFoam which will give you the directory FoamX with all the files needed for your first steps with rhoSimpleFoam."
I also will try it out today. I hope it is working under version 1.4.1 :-)
Thanks a lot
Old   February 26, 2008, 06:47
Default Hi to all, I set up a simple
matteo_gautero
Hi to all,
I set up a simple case to understand what rhoSimpleFoam. In the forum I found a discussion where they said that to set up the case I had work with rhoTurbFoam. So I set up the case with rhoTurbFoam and the I modified the fvSolution and fvSchemes dictionary with the corresponding file present in simpleFoam. When I run the case I receive this error message:
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
#0 Foam::error::printStack(Foam:stream&) in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libbasicThermophysicalMod els.so"
#4 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::hThermo(Foam::fvMesh const&) in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libbasicThermophysicalMod els.so"
#5 Foam::basicThermo::addfvMeshConstructorToTable<foa m::hthermo<foam::puremixture<f oam::consttransport<foam::speciethermo<foam::hcons tthermo<foam::perfectgas> > > > > >::New(Foam::fvMesh const&) in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libbasicThermophysicalMod els.so"
#6 Foam::basicThermo::New(Foam::fvMesh const&) in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libbasicThermophysicalMod els.so"
#7 main in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/rhoSimpleFoa m"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 Foam::regIOobject::readIfModified() in "/home/gauta/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/rhoSimpleFoa m"
Floating point exception (core dumped)
Can anyone help me?
Thanks
Old   February 26, 2008, 07:02
Default Hi, can you give me your em
ttian
can you give me your email? I can send you a file.
Just untar it under $FOAM_SOLVERS/compressible/rhoSimpleFoam which will give you the directory FoamX with all the files needed for your first steps with rhoSimpleFoam. I found it in this forum.
Bye
Old   March 3, 2008, 11:14
Default Hi, can anybody send me the
  #11
Marco Zardetto
sharmak is on a distinguished road
can anybody send me the file that I have to untar in the $FOAM_SOLVERS/compressible/rhoSimpleFoam directory in order to use the rhoSimpleFoam solver in FoamX?
The file I found in the forum (rhoSimpleFoam_FoamX.tar.gz)is a .unk file... I don't know how to use it.
Or anybody can send me an example to compile correctly the files (fvSolution, fvSchemes...) with this solver?
Thanks
Bye
sharmak is offline   Reply With Quote
Old   March 3, 2008, 11:23
Default Hi Marco I think you want t
  #12
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi Marco
I think you want to do something like that:
1- mv rhoSimpleFoam_FoamX.unk rhoSimpleFoam_FoamX.tar.gz
2- gunzip rhoSimpleFoam_FoamX.tar.gz
3- tar -xvf rhoSimpleFoam_FoamX.tar
and, I think you should get what you want
:o)
Cedric
cedric_duprat is offline   Reply With Quote
Default Hi Marco, when you save the
  #13
Francesco Boschetto
francesco_b is on a distinguished road
Hi Marco,
when you save the file, simply rename it rhoSimpleFoam_FoamX.tar.gz and you'll download the correct file. Then extract it and start to play
Regards
Francesco
francesco_b is offline   Reply With Quote
Old   March 3, 2008, 12:51
Default Thanks Francesco and Cedric,
  #14
Marco Zardetto
you are right. Now the solver is in FoamX but it gives error creating a new case! Probably there are some errors in the file.
I'm sorry but I'm new to OpenFoam...
Anyhow I've to study a compressible air flow in steady state. I started from rhoturbFoam solver and than I modified manually some files. When the simulation starts it plots this errors:
Exec : rhoSimpleFoam . v990_prova
Date : Mar 03 2008
Time : 18:22:51
Host : computer-marco
PID : 6983
Root : /home/simulation/OpenFOAM/simulation-1.4/run/tutorials/rhoTurbFoam
Case : v990_prova
Nprocs : 1
Create time
Create mesh for time = 0
#7 main
#9 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
What does it mean? How can I find the errors?
Thanks
Bye
Old   March 4, 2008, 03:15
Default Hi, maybe you have to chang
  #15
tian's Avatar
Tian
tian is on a distinguished road
maybe you have to change the fvScheme in "FoamX/defaults/system/" folder?
laplacian((rho*(1|A(U))),p) Gauss linear corrected
I am not sure it is the reason...
bye
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance.
tian is offline   Reply With Quote
Old   March 4, 2008, 03:43
Default Hi Marco, I think it could
  #16
Francesco Boschetto
Hi Marco,
I think it could be a BC problem, can you tell us which is your set of BC? Which changes did you make in the code?
Regards
Francesco
Old   March 4, 2008, 04:04
Default Hi, with my old post I want
  #17
tian's Avatar
Tian
with my old post I want to tell about you have to change the file fvScheme that you can open it in FoamX without error.
Bye
Old   March 4, 2008, 06:00
Default Hi Thomas, FoamX doesn't wo
  #18
Marco Zardetto
Hi Thomas,
FoamX doesn't work in spite of the change. Maybe other changes are necessary and I tried to do them, but nothing.... The error, when I create the new case, is this:
class org.omg.CORBA.UNKNOWN
Thanks anyway
Old   March 4, 2008, 06:05
Default Hi Francesco, maybe you are
  #19
Marco Zardetto
Hi Francesco,
maybe you are right, I modified the BC and the simulation starts but now it stops here:
Starting time loop
Time = 0.05
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 9.71047e-06, No Iterations 5
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.14451e-06, No Iterations 5
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 2.265e-06, No Iterations 6
#14 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
This is my problem, I think it is not difficult to solve but I'm not able:
I have an air duct with an inlet section and an outlet section. The motion is produced by a delta p between the two sections. Flow is compressible, turbulent and steady.
These are some of the changes I made to modify rhoTurbFoam solver:
application rhoSimpleFoam (in contolDict file)
ddtSchemes steadyState (in fvSchemes file)
SIMPLE (in fvSolution file)
Honestly I don't know how to put all the BC at time 0 (R, k, epsilon?). Do you think the mistake is here? Or in the solution for p?
These are the BC I put:
U=0 on the wall, zeroGradient on inlet and outlet
p=fixedValue on inlet and outlet, zeroGradient on the wall
k, epsilon, R, T zeroGradient (and internalField ?)
Please can you help me?
Thanks
Old   March 4, 2008, 06:15
Default Hi Marco, can you give me y
  #20
tian's Avatar
Tian
Hi Marco,
can you give me your email? I will send you my files.
Bye
Steadystate pressurebased compressible solver cosimobianchini OpenFOAM Running, Solving & CFD 1 July 19, 2010 14:45
Steadystate versus Transient solver pda OpenFOAM Running, Solving & CFD 1 July 11, 2007 08:36
Steadystate Vs Transient solver amitshah OpenFOAM Running, Solving & CFD 1 August 23, 2006 02:54
Steadystate Euler solver jelmer OpenFOAM Running, Solving & CFD 1 June 19, 2006 08:24
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 13:41
