RunTimeModifiable did not work
Old   October 27, 2005, 08:17
Default runTimeModifiable yes; did not
Maka Mohu
maka is on a distinguished road
runTimeModifiable yes; did not work with channelOodles solver. Is this normal? What should I do to make such option effective? The used timestep is just to check if the option is working, that is why it is big. Thanks.
application channelOoddns;
startFrom latestTime;
startTime 0
stopAt endTime;
endTime 150;
deltaT 0.1;
writeControl adjustableRunTime; // automatic time step.
writeInterval 0.1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
adjustTimeStep yes;
maxCo 3;
maxDeltaT 0.1;
-- INSERT -- 25,25 72%
maka is offline   Reply With Quote
Old   October 27, 2005, 08:49
Default Are you running an adjustable
Eugene de Villiers
eugene is on a distinguished road
Are you running an adjustable timestep? If so it will override deltaT to preserve the maximum Co number.
eugene is offline   Reply With Quote
Old   October 28, 2005, 10:19
Default yes I'm running adjustable tim
Maka Mohu
yes I'm running adjustable timestep but the parameter that I changed during run time was maxCo so if the file is read before each time step, then the solver should allow for the new modified maxCo. It did not. Thanks for your help.
Maka
Old   October 28, 2005, 11:43
Default Change something else in the c
Eugene de Villiers
Change something else in the control dictionary while running to see if it gets read, like writeFormat. If this change doenst take effect then you have some timestamp issue. If it does take effect, your problem is that the maxDeltaT is overriding the maxCo.
In this case I can suggest is that you check the source code of setDeltaT.H to see how it works.
Old   November 18, 2008, 08:05
Default Hi, I had the same problem
Wolfgang Heydlauff
wolle1982 will become famous soon enough
I had the same problem with turbFoam. I changed the turbFoam.C. Maybe you can get some hints how to change your channelOodles.C
See
http://www.cfd-online.com/OpenFOAM_D...tml?1227012935
wolle1982 is offline   Reply With Quote
Old   July 26, 2021, 16:56
Lukas Kutej
delsolman is on a distinguished road
wrong thread sorry
delsolman is offline   Reply With Quote
cvd can't work mahe Phoenics 0 February 25, 2008 22:01
why CFX help can't work? prayskyer CFX 5 December 17, 2006 16:15
i can't work it out,help me,thanks! ATao Siemens 1 August 7, 2005 10:48
How does work RMF? Julien FLUENT 0 May 5, 2005 20:35
Will the UDF work?? H.S.Fang FLUENT 0 December 27, 2001 21:21
