Y far from the wall
Like Tree1Likes
  • 1 Post By cosimobianchini
Old   October 16, 2006, 08:51
Default Hi all, i'm working on k-epsi
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
i'm working on k-epsilon LowRe turbulence model for compressible flow.
i was trying to implement the model proposed by Chien 1982, in which the damping function for mu depends on y+=y*u_tau/nu
where u_tau is the friction velocity, defined at the wall.
my question is:
do you have any suggestion on how to get y+ away from the wall?
thank you for your replies
cosimo
mgg likes this.
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   October 19, 2006, 14:17
Default Have a look at wallDist which
Mattijs Janssens
Have a look at wallDist which is a volScalarField of the distance to the nearest wall. Additionally you could transport the flow properties at that same nearest wall (see wallDistData) and do your calculation.
Old   October 20, 2006, 05:24
Default Thank you really much Mattijs
cosimo bianchini
Thank you really much Mattijs for answering.
Your suggestion was exactly what i was looking for.
I'll try to make it run for the Chien model and after that i was thinking about implementing a two layer turbulence model.
Since i'm a beginner in OF i was looking for some hints, do you maybe have some experience on this subject?
Thanks again for you help
cosimo
Cosimo Bianchini
Via Panciatichi, 92
Old   October 24, 2008, 09:36
Default Hi, I am trying to do the s
Fabian Braennstroem
braennstroem is on a distinguished road
I am trying to do the same as cosimo using:
wallPointYPlus::yPlusCutOff = 500;
wallDistData<wallpointyplus> y(mesh, Yplus);
Info << y.data() << endl;
This does unfortunately not work:
#0 Foam::error::printStack(Foam:stream&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/gcae504/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt in "/lib64/tls/libc.so.6"
#3 Foam::FaceCellWave<foam::wallpointyplus>::faceToCe ll() in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#4 Foam::FaceCellWave<foam::wallpointyplus>::iterate( int) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#5 Foam::FaceCellWave<foam::wallpointyplus>::FaceCell Wave(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<foam::wallpointyplus> const&, Foam::UList<foam::wallpointyplus>&, Foam::UList<foam::wallpointyplus>&, int) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#6 Foam::MeshWave<foam::wallpointyplus>::MeshWave(Foa m::polyMesh const&, Foam::List<int> const&, Foam::List<foam::wallpointyplus> const&, int) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#7 Foam::patchDataWave<foam::wallpointyplus>::correct () in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#8 Foam::patchDataWave<foam::wallpointyplus>::patchDa taWave(Foam::polyMesh const&, Foam::HashSet<int,> > const&, Foam::List<foam::field<double>*> const&, bool) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#9 Foam::wallDistData<foam::wallpointyplus>::correct( ) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#10 Foam::wallDistData<foam::wallpointyplus>::wallDist Data(Foam::fvMesh const&, Foam::GeometricField<double,>&, bool) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#11 main in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
#12 __libc_start_main in "/lib64/tls/libc.so.6"
#13 __gxx_personality_v0 in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s"
Floating exception (core dumped)
Would be nice, if anyone has a suggestion!?
Fabian
braennstroem is offline   Reply With Quote
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
Copy UDSI from wall to its wall shodow thiendinh FLUENT 0 December 15, 2008 05:16
match uds boundary condition in wall & wall-shadow pour FLUENT 0 May 20, 2008 08:56
LES with wall functions, wall boundary, Re 10000 subba CFX 4 July 10, 2007 05:04
wall & wall shadow net heat flux Barbaros FLUENT 1 August 5, 2006 02:00
