October 23, 2008, 08:48 |
Dear users,
I have read man
stephane sanchi
Rep Power: 18 |
Dear users,
I have read many threads about 'bounding problems for k and epsilon', but without finding how to solve it. I am trying to compute a free surface calculation with a boat. The mesh was generated using ICEMCFD Hexa. The cae crashes after 2-4 iterations with the following message : MULES: Solving for gamma Liquid phase volume fraction = 0.499998 Min(gamma) = -2.96063e-12 Max(gamma) = 1.01884 MULES: Solving for gamma Liquid phase volume fraction = 0.499998 Min(gamma) = -2.96285e-12 Max(gamma) = 1.01883 MULES: Solving for gamma Liquid phase volume fraction = 0.499998 Min(gamma) = -2.96507e-12 Max(gamma) = 1.01883 MULES: Solving for gamma Liquid phase volume fraction = 0.499998 Min(gamma) = -2.96729e-12 Max(gamma) = 1.01882 DILUPBiCG: Solving for Ux, Initial residual = 0.611633, Final residual = 8.16394e-07, No Iterations 625 DILUPBiCG: Solving for Uy, Initial residual = 0.673241, Final residual = 8.43185e-07, No Iterations 631 DILUPBiCG: Solving for Uz, Initial residual = 0.927937, Final residual = 8.75002e-07, No Iterations 564 DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.038253, No Iterations 4 DICPCG: Solving for pd, Initial residual = 6.54561e-09, Final residual = 6.54561e-09, No Iterations 0 DICPCG: Solving for pd, Initial residual = 6.54561e-09, Final residual = 6.54561e-09, No Iterations 0 DICPCG: Solving for pd, Initial residual = 1.36844e-07, Final residual = 1.2005e-08, No Iterations 1 DICPCG: Solving for pd, Initial residual = 3.54892e-08, Final residual = 3.54892e-08, No Iterations 0 DICPCG: Solving for pd, Initial residual = 3.54892e-08, Final residual = 3.54892e-08, No Iterations 0 DICPCG: Solving for pd, Initial residual = 1.63417e-07, Final residual = 1.93669e-08, No Iterations 1 DICPCG: Solving for pd, Initial residual = 4.80168e-08, Final residual = 4.80168e-08, No Iterations 0 DICPCG: Solving for pd, Initial residual = 4.80168e-08, Final residual = 4.80168e-08, No Iterations 0 time step continuity errors : sum local = 0.000631323, global = 8.45631e-07, cumulative = 8.45629e-07 DILUPBiCG: Solving for epsilon, Initial residual = 0.870335, Final residual = 32077.1, No Iterations 2001 bounding epsilon, min: -6.62374e+16 max: 1.14934e+17 average: -7.2268e+11 DILUPBiCG: Solving for k, Initial residual = 0.995697, Final residual = 8.46144e-05, No Iterations 2001 bounding k, min: -2.04339e+12 max: 8.30451e+14 average: 2.41778e+11 ExecutionTime = 282.88 s ClockTime = 284 s Courant Number mean: 0.252986 max: 452593 deltaT = 3.58683e-11 Time = 0.00503247 MULES: Solving for gamma [1] [3] ##00 Foam::error::printStack(Foam:stream&)Foam::error::printStack(Foam:stream&) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigFpeHandler(int)[2] #0 Foam::error::printStack(Foam:stream&)[0] in "/shared/OpenF#O0 AFoam::error::printStack(Foam:stream&)M/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #2 in [5] "#/0share dFoam::error::printStack(Foam:stream&)/OpenFOAM/Ope[4] n#F0O AFoam::error::printStack(Foam:stream&)M-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [3] #2 ?? in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigFpeHandler(int)?? in in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [5] #1 Foam::sigFpe::sigFpeHandler(int)"/shared/OpenFOAM in /O"p/elniFbO6A4M/-l1i.b5c/.lsiob./6l"i n[1] u#x36 4Gvoid Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int)ccDPOpt/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5 in /"l/isbh/alriendu/xO6p4eGncFcODAPMO/pOtp/elniFbOOApMe-n1F.O5A/Ml.isbo/"l i[2] n#u2x 64GccDPOpt/libOpenFOAM.so" [0] #2 in "/lib64/libc.so.6" The error message is much longer. This is only the beginning. I have tried to play with many parameters (deltaT, maxDeltaT, k and setFields, ...) but without success !!!!!!!!!!!! Stephane. |
[surface handling] Command line tool for finding the bounding box of an STL file | terrybarnaby | OpenFOAM Meshing & Mesh Conversion | 8 | November 4, 2016 13:09 |
SnappyHexMesh plane surface bounding box | podallaire | OpenFOAM Bugs | 22 | August 26, 2009 07:34 |
Bounding problem in running rasinterfoam | qtian | OpenFOAM Running, Solving & CFD | 4 | June 30, 2008 22:54 |
gridding when bounding surfaces are rough? | Herb Schilling | Main CFD Forum | 1 | December 1, 2000 05:58 |
Bounding frames increments | Ricky Wong | FLUENT | 3 | April 6, 2000 08:55 |
