How to use Spab function
Old   October 20, 2008, 11:16
Default Hello everybody, i´m using
booz is on a distinguished road
Hello everybody,
i´m using the following equation
tmp<fvvectormatrix> VEqn
fvm::div(-phi,V)
+ (gradU & V)
+ alpha & V // (*)
The problem is, that alpha and V are volVectorFields and (*) will be a scalar. Like in Programmers Guide for (*) i used
fvm::Sp(alpha&V, I) // I initialvector
In my createFields i use for I
dimensionedVector I
"I",
dimensionSet(0, 0, 0, 0, 0, 0, 0),
vector(1,1,1),
But i get the following error message:
createFields.H: In function 'int main(int char**)':
createFields.H:110: error: expected primary-expression before ')' token
AdjAlphaFoam_Vers2.C:81: error: no matching function for call to 'Sp(Foam::tmp<foam::geometricfield<double,> >, Foam::dimensionedVector&)'
make: *** [Make/linuxGccDPOpt/AdjAlphaFoam_Vers2.o] Error 1
Is the "Sp(a,b)" operator the right solution for to use (*) in OpenFoam?
For any answers i will be very happy!
Thanks a lot,
Khaled Totakhel
booz is offline   Reply With Quote
Old   October 22, 2008, 07:58
Default What is on like 110 in createF
Hrvoje Jasak
hjasak will become famous soon enough
What is on like 110 in createFields.H? Looks like you've got a syntax error. The operator fvm::Sp will take a scalar linearised field for the first argument and the field you are solving for as the second. Your second argument seems to be a dimensionedVector and not the thing you are solving for.
Hope this helps,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   October 22, 2008, 08:08
Default first off, I have no idea what
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
first off, I have no idea what you are trying to do
so this will be an answer based purely on the visual inspection of your constructor...
there is a comma after vector(1,1,1) that shouldnt be there.
niklas is offline   Reply With Quote
Old   October 22, 2008, 08:46
Default Hello Niklas, i'll try the
Hello Niklas,
i'll try the Sp(a,b)-operator to solve (*) implicit.
In Programmers Guide "a" must be a scalar or volScalar -typ and "b" a vol<type>Field. I thought if i use an inititalvector I for b, i reach my goal!
Regards,
Khaled
Old   October 22, 2008, 08:51
Default Hello Hrvoje, thanks for yo
Hello Hrvoje,
thanks for your answer. But how can I use an initialvector (1,1,1) as volVectorField for the second argument of Sp(a,b) without:
volVectorField I
IOobject
"I",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh
in my createFields?
Regards,
Khaled
udf function!! shayej FLUENT 1 February 5, 2009 08:37
Cp as a function Mareike CFX 4 April 8, 2008 04:55
If function PANKAJ CFX 3 January 13, 2008 03:53
Stream Function - Potential Function coordinates harish Main CFD Forum 8 June 25, 2005 13:18
Max y+ as a function of Re Fred Uckfield Main CFD Forum 6 October 17, 2001 11:15
