Heat transfer in liquid water suggestions for chioce of solver
Old   October 17, 2008, 09:48
Default Hi Bernard, I realised an h
  #21
Christian Lindbäck
christian is on a distinguished road
Hi Bernard,
I realised an hour ago that pressure in compressible solvers is of dimension Pascal and that pressure in incompressible solvers is of dimension pressure/density. The solver is running now. Sorry, I should have posted a message that everything is well, for now
christian is offline   Reply With Quote
Old   July 23, 2009, 06:32
J. Cai
chiven is on a distinguished road
Hi, dear foamers, When I run the boussinesqBuoyantSimpleFoam solver on my own case, the following error appears:
Time = 0.05
DILUPBiCG: Solving for Ux, Initial residual = 0.989258, Final residual = 0.0103564, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.973745, Final residual = 0.0111817, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.975119, Final residual = 0.00821149, No Iterations 1
GAMG: Solving for p, Initial residual = 9.53872e-06, Final residual = 5.94514e-07, No Iterations 1
time step continuity errors : sum local = 1.07053e+17, global = -1.94455e+13, cumulative = -1.94455e+13
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.00430228, No Iterations 1
bounding epsilon, min: -1.3712e+37 max: 4.32279e+38 average: 7.36798e+32
#0 _ZN4Foam5error10printStackERNS_7OstreamE-0xb34150
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libOpenFOAM.so"
#1 _ZN4Foam6sigFpe13sigFpeHandlerEi-0xad1820
#2 Uninterpreted: [0xa0000000000107e0]
#3 _ZNK4Foam13LimitedSchemeIdNS_14vanLeerLimiterINS_6 NVDTVDEEENS_10limitFuncs6magSqrEE7limiterERKNS_14G eometricFieldIdNS_12fvPatchFieldENS_7volMeshEEE-0x1d0538e
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libfiniteVolume.so"
#4 _ZNK4Foam33limitedSurfaceInterpolationSchemeIdE7we ightsERKNS_14GeometricFieldIdNS_12fvPatchFieldENS_ 7volMeshEEE-0x1f1c680
#5 _ZNK4Foam2fv21gaussConvectionSchemeIdE6fvmDivERKNS _14GeometricFieldIdNS_13fvsPatchFieldENS_11surface MeshEEERNS3_IdNS_12fvPatchFieldENS_7volMeshEEE-0x1f192a0
#6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64GccDPOpt/boussinesqBuoyantSimpleFoam"
#7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64GccDPOpt/boussinesqBuoyantSimpleFoam"
#8 _ZN4Foam10boussinesq9RASModels8kEpsilon7correctEv-0x28bce90
in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64GccDPOpt/libboussinesqRASModels.so"
#9 main in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64GccDPOpt/boussinesqBuoyantSimpleFoam"
#10 __libc_start_main-0x734df0
in "/lib/tls/libc.so.6.1"
#11 _start in "/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64GccDPOpt/boussinesqBuoyantSimpleFoam"
Floating exception
Any comments? thank you very much in advance.
chiven is offline   Reply With Quote
Old   July 23, 2009, 07:09
Assistant Moderator
Bernhard Gschaider
Time = 0.05
Floating exception
Several questions arise from your output:
- why do you have a timestep!=1 for a steady solver (not that it matters much, but it gives me the suspicion that the settings you're using were meant for a transient solver)
- is this the first time-step where continuity explodes?
- do you have relaxation?
- was the vanLeer your idea?
- what are the boundary conditions?
Bernhard
Old   July 23, 2009, 07:51
J. Cai
Hello, Bernhard, thank you very much for your precious comments.
About the relaxation, it is shown as follows.
relaxationFactors
p 0.15;
U 0.3;
k 0.3;
epsilon 0.3;
R 0.7;
nuTilda 0.7;
T 0.3;
Sorry, I have to post the results in the follows for the reason of too many characters.
Old   July 23, 2009, 07:52
J. Cai
I changed the deltaT=1, and do calculation again, the results are shown in follows.
Create time
Create mesh for time = 0
Reading transportProperties
Reading environmentalProperties
Reading field p
Reading field T
Reading field Q
Reading field U
Creating field alphaEff
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
Cb 1.44;
alphaEps 0.76923;
Starting time loop
Convergence criterion for U = 0.001
Convergence criterion for p = 0.01
Convergence criterion for T = 0.001
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00959259, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0060194, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.00859174, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.00880705, No Iterations 9
time step continuity errors : sum local = 0.000515452, global = -1.32363e-05, cumulative = -1.32363e-05
DILUPBiCG: Solving for epsilon, Initial residual = 0.0516045, Final residual = 0.000326048, No Iterations 1
bounding epsilon, min: -1.05947 max: 85.5521 average: 2.55034
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0173683, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 0.000886871, Final residual = 2.99323e-06, No Iterations 1
ExecutionTime = 142.679 s ClockTime = 143 s
Initial residual for U = 1
Initial residual for p = 1
Initial residual for T = 0.000886871
Time = 3
DILUPBiCG: Solving for Ux, Initial residual = 0.998546, Final residual = 0.0174537, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.999007, Final residual = 0.0185219, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.999519, Final residual = 0.0171578, No Iterations 1
GAMG: Solving for p, Initial residual = 0.984913, Final residual = 0.00683274, No Iterations 3
time step continuity errors : sum local = 904905, global = -7597.79, cumulative = -7597.66
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.00633617, No Iterations 1
bounding epsilon, min: -2.0693e+12 max: 3.04074e+13 average: 2.12447e+08
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.00279179, No Iterations 1
bounding k, min: -2.59096e+10 max: 1.58311e+12 average: 4.51853e+06
DILUPBiCG: Solving for T, Initial residual = 0.0518603, Final residual = 0.00156515, No Iterations 1
ExecutionTime = 357.442 s ClockTime = 358 s
Initial residual for U = 0.999519
Initial residual for p = 0.984913
Initial residual for T = 0.0518603
Time = 5
time step continuity errors : sum local = 1.07053e+19, global = -1.94455e+15, cumulative = -1.94455e+15
Floating exception
Old   July 23, 2009, 08:16
Assistant Moderator
Bernhard Gschaider
<snip>
About the boundary condition, they are shown as follows.
<snip>
No Idea what could be the problem. Two recommendations:
- when starting a new case base the settings on a stable calculation with the same solver. Usually such settings can be found in $FOAM_TUTORIALS. So what I'd recommend is to use fvSchemes, fvSolution and controlDict from the buoyantSimple(!)Foam-hotroom as a first guess for your case. The references to vanLeer indicate that this is not the case for your calculation
- for outflows that have zeroGradient for U don't use zeroGradient for transported quantities like k, epsilon and T. Use inletOutlet. Otherwise things might explode when you get a backflow there
Bernhard
Solver for heat transfer calculation with water media benyamin1 OpenFOAM Running, Solving & CFD 6 January 27, 2011 04:26
Liquid Metals and Heat Transfer juanltm OpenFOAM Running, Solving & CFD 7 October 28, 2009 05:00
Solid-Liquid heat transfer Tu CFX 0 August 17, 2008 17:42
Heat transfer from solid to liquid Richard FLUENT 2 January 30, 2006 04:10
Heat Transfer from Solid To Liquid! Richard FLUENT 1 January 20, 2006 05:43
