September 22, 2008, 21:59 |
hi,
when i use "setParabolic
weihong yao
hi,
when i use "setParabolicInlet" application,it show: setParabolicInlet /home/user/skolan/OpenFOAM/skolan-1.3/run/tutorials/sonicFoam backwardStep inlet 0.01 -z_noncenter -parallel -y_noncenter ----------------------------------------------------------------------------- It seems that there is no lamd running on the host newton. This indicates that the LAM/MPI runtime environment is not operating. The LAM/MPI runtime environment is necessary for MPI programs to run (the MPI program tired to invoke the "MPI_Init" function). Please run the "lamboot" command the start the LAM/MPI runtime environment. See the LAM/MPI documentation for how to invoke "lamboot" across multiple machines. ------------------------------------------------- how to fix it?thank you! ps:I use OF1.4 IN SUSE10.2. |
September 23, 2008, 06:57 |
If you're using the setParabol
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If you're using the setParabolicInlet that floats around here, be advised that it doesn't work correctly on parallel cases (at least the version I wrote). Therefore the -parallel option should not be used (and it only makes sense if you've got an mpirun, or similar, before the call to the solver.
Bernhard
September 24, 2008, 02:20 |
hi.
thank you for your answer
weihong yao
hi.
thank you for your answer.but now i do not know what can i do? |
September 24, 2008, 05:48 |
Try running it without -parall
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Try running it without -parallel
September 24, 2008, 21:50 |
hi,
thank you!but it doesn't
weihong yao
hi,
thank you!but it doesn't work.it show Usage:setParabolicInlet <root>.....-z_noncenter -parallel -y_noncenter, |
September 25, 2008, 07:57 |
Try
setParabolicInlet . backw
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Try
setParabolicInlet . backwardStep inlet 0.01 -z_noncenter The dot is important. And the stuff iwht a - in front is optional
September 26, 2008, 03:11 |
ok.i will try it!thank you1
weihong yao
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
The setParabolicInlet problem | ivanyao | OpenFOAM Running, Solving & CFD | 6 | August 27, 2008 22:59 |
Problem in Modelling Heat Transfer Problem | Deepak R | FLUENT | 1 | December 6, 2007 09:37 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
