Create GeometricField without IOobject
Old   August 14, 2008, 10:23
Default Hello, sounds trivial, but ho
nadine
sounds trivial, but how do I create a volScalarField, if I have a Field<double> and a volMesh?
Here mesh.Sf() and U are two volVectorFields from which the operator& calculates the inner product, a scalar field:
Field<double> Phi=mesh.Sf() & U;
But later I need a volScalarField with the values of Phi, and I see no possibility to construct this volScalarField although all geometric information is available.
The problem is that every GeometricField<...> constructor requires an IOobject, and every IOobject constructor requires a filename, so that GeometricFields can never be generated on the fly (unless copied from another GeometricField), but must always be read from a file.
Is this true?
N. Blanc
Old   August 14, 2008, 15:18
Default correction: 1) "Here mesh.
nadine
correction:
1)
"Here mesh.Sf() and U are two volVectorFields..."
should read
"Here mesh.Sf() and U are a surfaceScalarField and a volVectorField..."
2)
"But later I need a volScalarField with the values of Phi, and I see no possibility to construct this volScalarField..."
should read
"But later I need a surfaceScalarField with the values of Phi, and I see no possibility to construct this surfaceScalarField..."
Still the question is:
How can I create a GeometricField from a Field and a Mesh without reading from an IOobject/file?
Best,
N. Blanc
Old   August 15, 2008, 07:13
Default GeometricField.H has all the c
Eugene de Villiers
eugene is on a distinguished road
GeometricField.H has all the constructors. There are many. For an example on how to create a field without reading, check this file:
src/finiteVolume/lnInclude/createPhi.H
To reconstruct a face field:
fvc::reconstruct(phi);
or
fvc::average(phi);
Depending on what you want to achieve.
eugene is offline   Reply With Quote
Old   August 15, 2008, 09:24
Default Thank you, Eugene! My mistake
nadine
Thank you, Eugene!
My mistake was that I thought an IOobject is always initialized from a file. The example createPhi.H made things clearer.
NB
How to convert from GeometricField to fvMatrix waynezw0618 OpenFOAM Running, Solving & CFD 2 January 8, 2021 16:35
IOobject r2d2 OpenFOAM Running, Solving & CFD 20 May 5, 2016 08:16
Manipulation of cellvalue of a geometricField ivan_cozza OpenFOAM Running, Solving & CFD 2 September 25, 2008 13:58
Duplicate GeometricField reimund OpenFOAM Running, Solving & CFD 9 June 9, 2008 13:47
Accessing data of geometricField bird OpenFOAM Running, Solving & CFD 1 August 28, 2007 18:21
