CheckYPlus bug
Like Tree1Likes
  • 1 Post By andersking
Old   July 18, 2007, 00:17
Default OK, with 1.4 version it seems
paka is on a distinguished road
OK, with 1.4 version it seems there is a bug.
CheckYPlus does not work, it requires 'p' file form time-step directory, which in 1.4 version is called 'pd'.
Looks like a simple thing, but I'm not familiar with OpenFOAM code yet, so I leave it for others
BTW. Why version 1.4 seems to be so buggy? Quite often I can read somebody complaints something does not work or is missing.
Regards,
K
paka is offline   Reply With Quote
Old   July 18, 2007, 03:07
Default "but I'm not familiar with Ope
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
"but I'm not familiar with OpenFOAM code yet, so I leave it for others"
In that case I would recommend you keep your expert comments to yourself. If you can contribute in a way that is productive please do so, if not then please stop ranting about the code being buggy.
msrinath80 is offline   Reply With Quote
Old   July 18, 2007, 14:42
Default "expert comments" - that's wha
"expert comments" - that's what I "like" about some people.
BTW. I am not ranting, just stating the fact that something doesn't work.
No more comments.
Old   July 19, 2007, 07:04
Default Foam has various pressure defi
Eugene de Villiers
eugene is on a distinguished road
Foam has various pressure definitions which makes writing general utilities cumbersome in some instances.
Specifically, p can be absolute pressure, kinematic pressure (p/rho) or pd - pressure without the gravity component.
checkYPlus was written to work with incompressible flow with pressures of the type p/rho only. This has always been the case and is certainly not a bug introduced in 1.4. It will not and has never worked with interFoam, buoyantFoam or other compressible solution fields. Feel free to modify it do do so though.
eugene is offline   Reply With Quote
Old   July 30, 2008, 04:18
Default where is checkYPlus gone in Op
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
where is checkYPlus gone in OpenFOAM 1.5?
br
Stefan Radl
sradl is offline   Reply With Quote
Old   July 30, 2008, 04:34
Default Try yPlusLES or yPlusRAS An
Andrew King
andersking is on a distinguished road
Andrew
lth likes this.
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
