July 16, 2008, 21:48 |
hi,
when i add a new boudary
weihong yao
Rep Power: 17 |
hi,
when i add a new boudary condition.everything goes ok,but when i type "wmake libso" ,it show "/home/ivan/OpenFOAM/OpenFOAM-1.4/wmake/wmake: cannot make.Make directory does not exist",i don't know why.the follow is my step. 1.decompressing the file which i download on the website.put it in ~/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/ fields/fvPatchFields/derivedFvPatchFields/ and /home/OpenFOAM/OpenFOAM-1.3/src/ finiteVolume/lnInclude/ 2.and then modify the Make/files parabolicVelocityFvPatchVectorField.C LIB = $(FOAM_ivan_LIBBIN)/libmyBCs and modify the Make/options files ~/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/ fields/fvPatchFields/derivedFvPatchFields/parabolicVelocity and /home/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/ parabolicVelocity 3.type "wmake libso" and it show up the error message. my c++ is rusty.could anyone tell me why. thanks |
July 16, 2008, 23:31 |
Hi !
Did you type "wmake li
Mathieu Olivier
Rep Power: 17 |
Hi !
Did you type "wmake libso" in the following folder : " ~/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/ " ? Mathieu |
July 17, 2008, 21:05 |
HI,
I type it in the terminal
weihong yao
Rep Power: 17 |
HI,
I type it in the terminal windows.am i wrong? Ivan |
July 18, 2008, 10:22 |
Hi Ivan,
Of course in the t
Mathieu Olivier
Rep Power: 17 |
Hi Ivan,
Of course in the terminal. Just to be clear : 1. open a terminal 2. type : cd ~/OpenFOAM/OpenFOAM-1.3/src/finiteVolume 3. then type : wmake libso If this does not work, tell me where you downloaded your files for the new BC. Also tell me if you work in OF 1.3 or 1.4 (because your error message says 1.4 and you talk about 1.3 in the rest of your message; you should maybe check your .bashrc...) Good luck ! Mathieu |
September 2, 2009, 07:23 |
problem: wmake libso
Madeleine L Combrinck
I am attempting to implement the parabolicVelocity boundary condition using OF-1.5.
When compiling the dynamic library (wmake libso), I get the error: make: *** No rule to make target `parabolicVelocityFvPatchVectorField.dep', needed by `Make/linuxGccDPOpt/dependencies'. Stop. I have tried the "wmakeFilesandOptions" command, but got the same error. As an alternative I attempted to implement the utility setParabolicInlet, but got a similar error: make: *** No rule to make target `setParabolicInlet.dep', needed by `Make/linuxGccDPOpt/dependencies'. How do I solve this problem? |
January 30, 2010, 15:45 |
#6 | |
Rep Power: 16 |
make: *** No rule to make target `lisbo'. Stop. when i trying to compile WallHeatFlux boundary condition it is in the attachment can any one help best regards |
March 12, 2010, 10:54 |
Re: problem: wmake libso
#7 | |
Dominic Piro
Rep Power: 16 |
I have gotten that problem before when I copied over some source code to modify. I had copied the Make directory to make sure I got all of the libraries I needed. What I had forgotten to do was make sure all of the folders lined up in the "files" file. (I had added a "my" in front of the folder.) When I went through and made sure all of the files and folders matched what was really there, the error went away. I hope that helps. |
no-slip boudary condition in udf | zhao | FLUENT | 1 | June 26, 2019 22:46 |
symmetry boudary condition | MAB | CFX | 1 | August 13, 2008 21:25 |
outlet boudary condition for a flow in the pipe | Atit | CFX | 2 | November 9, 2004 17:43 |
outflow boudary condition | damien | FLUENT | 4 | July 23, 2003 04:55 |
outflow boudary condition in SIMPLE algorithm | dallybird | Main CFD Forum | 0 | March 6, 2003 11:55 |
