Supersonic flow over ramp
Old   June 13, 2008, 04:05
Default Hello i am trying to model
srinath
srinath is on a distinguished road
Hello
i am trying to model supersonic flow over a ramp.
These are my bc's and domain.
Inlet--supersonic inlet (P,U,T) specified.
Outlet--Extrapolated outlet (dp/dn,du/dn.dT/dn=0),
since flow at outlet is supersonic.
top of channel--symmetry(to simulate an infinite domain).
bottom of channel before ramp--symmetry.
ramp--slip.
When i run the case with these bc's, the solution blows up.
I would appreciate it if someone tell me what i am doing wrong
Regards
Srinath
srinath is offline   Reply With Quote
Old   June 14, 2008, 03:07
Default Solved it, was using wrong val
srinath
Solved it, was using wrong values of R and Cv
Old   June 16, 2008, 08:43
Default Hi Srinath I used the same
Varun Vikas
varun is on a distinguished road
Hi Srinath
I used the same conditions and could not solve the problem - the solutiuon blew up. I used U = 2, p = 1, T = 1, Cv = 1.785, R = 0.714. What values didi you use?
How far above the ramp did u put you rfarfiedl condition?
Regards
Varun
varun is offline   Reply With Quote
Old   June 16, 2008, 09:58
Default Hi Vikas I converted everyt
srinath
Hi Vikas
I converted everything to SI, since otherwise comparison won't be correct. R=.714,Cv=1.785 does not correspond to air, for which we have test results.
Domain is exactly as on the nasa webpage
http://www.lerc.nasa.gov/WWW/wind/va...dge/wedge.html
with symmetry bc at top of domain.
I used R=287(for air), then get Cv(assume gamma=1.4), then a, then U = 2.5*a
similarly convert P,T etc in NASA problem to SI
Note that i ran it for Mach no=2.5(not 2.0), Angle was underpredicted by about 5 degrees.
Regards
Srinath
Displaying Error: cx-set-color-ramp:... Hendawi FLUENT 3 July 9, 2016 03:33
LES supersonic flow ziooscuro OpenFOAM Running, Solving & CFD 1 March 5, 2011 00:56
15 digree ramp problem sriram Main CFD Forum 0 December 24, 2008 08:29
Supersonic flow past a wedge with counter flow Mahesh Bailakanavar FLUENT 0 February 14, 2008 00:21
supersonic flow ariel narvaez FLUENT 0 June 13, 2001 11:54
