Accessing The Two Phase Properties
Old   May 19, 2008, 08:51
Default People from here, How do
Thiago Reis Carvalho Cabral Miliante
miliante is on a distinguished road
People from here,
How do I access each phase property? Like rho, mu and nu? In my case for air and water, which I've set in the transportProperties file.
Thanks in advance.
miliante.
miliante is offline   Reply With Quote
Old   May 19, 2008, 19:44
Default which solver? try below dime
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
which solver?
try below
dimensionedScalar rho(transportProperties.lookup("rho"));
or
dimensionedScalar rho;
rho=dimensionedScalar(transportProperties.lookup(" rtho"));
Su Junwei
su_junwei is offline   Reply With Quote
Old   June 19, 2013, 07:55
abe
ABE
abe is on a distinguished road
Hi Junwei,
I need to call twoPhaseProperties inside a turbulence model (k omega sst). I mean inside ' void kOmegaSSTRebound::correct()'
How would it be possible?
I have tried the following but wiothout success.
const dimensionedScalar& rho1 = transport_.rho1();
or
dimensionedScalar rho1(transportProperties.subDict("phase1").lookup( "rho"));
abe is offline   Reply With Quote
Old   June 19, 2013, 08:35
Nima Samkhaniani
nimasam is on a distinguished road
did you introduce following objects:transport_ , transportProperties in your code?
if not, then how do you want to call a member of it?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 19, 2013, 08:52
abe
ABE
Hi Nimasam,
Thanks for your comment.
The rho1, and rho2 can be called through twoPhaseProperties. And if one follows the hierarchy (creatFields.H, then turbulenceModel.C, then RansModel.C, and finally kOmegaSST.C), it can be seen that twoPhaseProperties has passed inside the kOmegaSST.C by the name of 'transport':
kOmegaSST::kOmegaSST
const volVectorField& U,
const surfaceScalarField& phi,
transportModel& transport,
const word& turbulenceModelName,
const word& modelName
However, I do not still know how to use it. Any comment is highly appreciated.
ABE
Old   June 20, 2013, 05:04
Nima Samkhaniani
you can use following structure to read from dict:
rho1_
dimensioned<scalar>::lookupOrAddToDict
"rho1",
coeffDict_,
1.0 //your default value
transportModel class has no member which pointed to transportProperties dict
Question of properties in two phase solver mmjhuang OpenFOAM Running, Solving & CFD 2 October 29, 2012 22:56
UDF help on accessing values shashikant FLUENT 0 December 22, 2005 09:41
Accessing flow properties at certain points inUDFs nicolas FLUENT 2 February 14, 2005 20:42
Accessing material properties in UDF Henrik Widell FLUENT 0 March 18, 2002 09:49
UDF & Accessing Turbulence Properties Dimal FLUENT 0 March 5, 2002 13:14
