Can my machine do parellel processing
Old   April 24, 2008, 03:51
Default Hello World. I'm woundering
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I'm woundering if my machine can do parallel processing. Is there a list with supportet processors?
I'm using a Intel Core2Duo T7500 @ 2.2 GHz.
Greetings.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 24, 2008, 04:07
Default Your machine has two cores, so
Patricio Bohorquez
pbohorquez is on a distinguished road
Your machine has two cores, so YES you can. Decompose your domain in two subdomains with the utility decomposePar, and run the parallel case as indicated in the User guide, with np being 2.
pbohorquez is offline   Reply With Quote
Old   April 24, 2008, 04:13
Default Unfortunately I'm running my l
sega's Avatar
Sebastian Gatzka
Unfortunately I'm running my linux-system in a virtual environment on a Windows machine.
I suppose the virtualbox is not supporting multiple cores.
When I do the steps to for parallel running and check the cpu workload with 'top' I have two solvers running with each nearly 50 % ...
That doesn't look like real parallel running ...
Old   April 24, 2008, 04:35
Default On the other hand, if I run th
sega's Avatar
Sebastian Gatzka
On the other hand, if I run the single solver, I get 100% workload in linux and 100% workload on EACH core in windows ...
Maybe thats all I can sqeeze out of my machine ...
Old   April 24, 2008, 05:59
Default You should install Linux! http
Billy
billy is on a distinguished road
I suggest simulate a simple case like lid-driven cavity with 80x80 cells or so with 1 and 2 processes and compare the computation time.
billy is offline   Reply With Quote
Old   April 24, 2008, 12:54
Default We tested damBreak and found O
mellanoxuser
We tested damBreak and found OpenFOAM to be highly parallel. As # cores increase, the wall clock time greatly decreases - Check out also the InfiniBand topics under http://www.cfd-online.com/OpenFOAM_D...tml?1173649250
Most solvers have cases for each # procs (nproc2, nproc4...etc) and for cluster cofiguration, you just have to specify a hostfile with the mpirun command.
Hope this helps!
Old   April 27, 2008, 10:14
Default Well I have tested my dam brea
sega's Avatar
Sebastian Gatzka
Well I have tested my dam break problem.
Running in parallel it's just half the time.
Obviously the virtual environment does support miltiple cores.
How to use parellel mode with user cel function? frank CFX 3 November 15, 2008 14:50
Not able to copy the text file from one machine to another machine drive using Cgi script gtselvam OpenFOAM Bugs 2 October 22, 2007 06:44
I-Radiation Equation problem with CFX Parellel Scott CFX 2 January 9, 2007 20:39
parallel processing problem with multiproc machine hajra_rabaeto!!!!!!! FLUENT 2 January 28, 2006 19:11
64 Bit machine P FLUENT 7 June 24, 2005 13:17
