Looping over variables within timestep
Old   February 28, 2008, 15:10
Default Hi, I'm solving an electro-
Ola Widlund
olwi is on a distinguished road
I'm solving an electro-hydrodynamic problem with OpenFOAM. My solver is transient. To get a stable solution, I think I need to loop a couple of times over the variables WITHIN each time step, to get the non-linear coupling right.
1) Is correction loops within time steps as simple as it looks in the standard PISO solvers ? That is, just have another go at the equations, no extras? I'm not risking messing up the implicit time-stepping or something?
2) Does it make any sense to apply the features for underrelaxation (as used in steadystate solvers) also in a transient solver? Is this at all possible to combine?
Thanks for any advice,
Ola
olwi is offline   Reply With Quote
Old   February 28, 2008, 15:27
Default 1) Yes - just put a loop and k
Hrvoje Jasak
1) Yes - just put a loop and keep it simple
2) Yes. Have a look at transientSimpleFoam on:
http://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Core/Ope nFOAM-1.4.1-dev/applications/solvers/incompressible/transientSimpleFoam/transien tSimpleFoam.C?revision=53&view=markup
Beware, if you wish to use under-relaxation, you have to grab the reference field within the loop, using eg. p.storePrevIter();
Enjoy Ola, good to hear from you again,
Hrv
Hrvoje Jasak
Old   February 28, 2008, 16:07
Default Perfect, Hrv, this should do i
Ola Widlund
Perfect, Hrv, this should do it...
Thanks for the info!
/Ola
Help! Function not LOOPing xtrios FLUENT 2 July 17, 2008 15:44
looping rr123 FLUENT 1 July 8, 2008 17:49
Looping in UDF!!! safa FLUENT 0 December 11, 2007 08:07
Accessing Variables from Previous Timestep Vinayak Barve FLUENT 1 March 10, 2004 07:40
Looping over cells Karl FLUENT 4 March 26, 2002 21:18
