About turbulentForceAndTorque
Old   February 12, 2008, 16:43
Default one question about the way the
pbo
Patrick Bourdin
pbo is on a distinguished road
one question about the way the viscous force is computed in turbulentForceAndTorqueFunctionObject.C:
// Viscous component
viscousForces[patchI] =
gSum
-nuEff.boundaryField()[curPatch]*
U.boundaryField()[curPatch].snGrad()*
mesh.magSf().boundaryField()[curPatch]
This is only valid in regions where the velocity field is more or less linear (snGrad being approximated by a one sided finite difference if I am not mistaken). In other words, for models with wall functions (log law), the above formulation will give incorrect viscous force estimates at the wall. Am I correct?
pbo is offline   Reply With Quote
Old   February 12, 2008, 17:07
Default I've also wondered about this
sek
Sung-Eun Kim
sek is on a distinguished road
I've also wondered about this and haven;t had time to look into the code. If the slip velocity (extrapolated using the wall-law) is somehow patched on the wall faces and the consistent eddy viscosity is used, the aboce expression should give correct wall-shear.
I'm not sure this is the way the OF works.
sek is offline   Reply With Quote
Old   February 14, 2008, 05:29
Default I am not familiar with this fu
Eugene de Villiers
eugene is on a distinguished road
I am not familiar with this function object (I guess it does the same as my liftDrag function object), but I can confirm that boundary values of nuEff on a wall will include the effects of wall functions if they are present in the turbulence model.
eugene is offline   Reply With Quote
