Saving pressure field in simpleFoam
Old   February 10, 2008, 17:40
Default Hi, In simpleFoam.C, runTim
J. T.
cpplabs is on a distinguished road
In simpleFoam.C, runTime.Write() is used to write results, and simpleFoam p.storePrevIter() is called to store the pressure field of the previous iteration. Because the WOpt_ member in the copy constructor of GeometricField is always set to be NO_Write, and it seems that the write function always export the pressure field for the previous iteration (not p itself), pressue is always missing from the export.
Can someone tell me how to fix the problem or what part of my understanding is wrong?
Thanks.
// construct as copy
template<class> class PatchField, class GeoMesh>
Foam::GeometricField<type,>::GeometricField
const GeometricField<type,>& gf
DimensionedField<type,>(gf),
timeIndex_(gf.timeIndex()),
field0Ptr_(NULL),
fieldPrevIterPtr_(NULL),
boundaryField_(*this, gf.boundaryField_)
if (debug)
Info<<>::GeometricField : "
"constructing as copy"
<<>info() << endl;
if (gf.field0Ptr_)
field0Ptr_ = new GeometricField<type,>
*gf.field0Ptr_
this->writeOpt() = IOobject::NO_WRITE;
cpplabs is offline   Reply With Quote
Old   February 10, 2008, 19:47
Default Nice one. Go to OpenFOAM-1
Hrvoje Jasak
hjasak will become famous soon enough
Nice one. Go to
OpenFOAM-1.4.1-dev/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricF ield.C
look for the function void Foam::GeometricField<type,>::storePrevIter() const
and in the second part do the following:
fieldPrevIterPtr_ =
IOobject
this->name() + "_prev",
this->time().timeName(),
this->db()
*this
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   February 10, 2008, 20:50
Default Hi, Thanks for the workaro
J. T.
Thanks for the workaround. I did further study into the code and found that "ConstructFromTmp" makes the difference because the following contructor. If ConstructFromTmp is turned on (defined), regIOobject(df) will be used instead of regIOobject(df, true), and the objectRegistry registration will not be transfered to the copy.
My further question is what is the purpose of ConstructFromTmp? It is used at several locations in the code, what different does this switch make?
Regards,
JT
template<class>
DimensionedField<type,>::DimensionedField
const DimensionedField<type,>& df
# ifdef ConstructFromTmp
regIOobject(df),
# else
# endif
Field<type>(df),
mesh_(df.mesh_),
dimensions_(df.dimensions_)
SimpleFoam pressure driven flow gzink OpenFOAM Running, Solving & CFD 1 July 2, 2013 14:23
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
Pressure Far Field BC Zhen FLUENT 4 January 24, 2005 07:53
about pressure far field fan Qunbo FLUENT 4 June 18, 2002 23:24
